The only thing I have seen cause anything like this is a high suds level in the waste water container. Usually caused by using pre cleaners on spots on the fabric. Those pr-ecleaners, i.e. Resolve, etc. create a LOT of excess suds in the waste water that can be sucked up in places they shouldn't be.
SOURCE: My Bissell Proheat is not spraying water. What is ...
It is very simple and inexpensive to fix. All you need to do is replace the pump belt. Here is the belt you need:
Bissell Proheat Pump Belt
SOURCE: I have a bissell proheat 2x and it leaks water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
heatman101
fkj
SOURCE: Bissell 9500 Proheat 2X won't dispense fluid.
heatman101
fgjhdjk
SOURCE: Bissell Proheat 9500 won't spray water
heatman101
ukyr
Worked on my Bissell 9500 ProHeat and found the answer:corrosion around the screw on the heater
