The control panel seems to be operating well, but the oven elements are not heating, and the ticking that is normally heard during initial heat-up does not sound. I could not find its wiring diagram anywhere, and I need it to find the cause of the failure. Can you please e-mail me the wiring diagram, or let me know how I can obtain it? Thanks, Ezra Baruch
SOURCE: oven elements dont work / stove top works fine
Repair person also shut the power off before replacing the fuse...
SOURCE: Looking for the part no.
the part you need is called the upper oven hi limit thermostat any appliance parts store can get it with your model number and any stove wire will do if you cant find it there then try here http://www.pcappliancerepair.com/cgi-bin/promotehome.cgi?affiliate_id=GSMK01ag
SOURCE: Electric Oven not getting hot enough
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
SOURCE: Frigidaire electric range smooth top with no oven function
although you dont have hte model number , that is indeed a correct and valid part number for the control lists for a about $120. since your back there give a quick look at the wiring into the unit, is that ok ??? adn where the burnout is on the control does it appear to have shorted out against the back wall??? perhaps a relay on the board just blew??? i really wouldn't thinkn tha another component was goning to make that go bad, also ck the bake and broil elements for continuity, perhapa wire fell off the element blowing out the control
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
