My gsl25jfxblb GE side by side ice maker won't stop making ice. It overflows out of the bin and fills the shelf below with ice. Then when we open the freezer door to remove some food, ice spills every
My gsl25jfxblb GE side by side ice maker won't stop making ice. It overflows out of the bin and fills the shelf below with ice. Then when we open the freezer door to remove some food, ice spills everywhere. Is there an arm that should recognize when the bin is full and then turn ice maker off? Any help is greatly appreciated!!
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know. http://appliance911seabreeze.com/
make sure your refrigerator unit is level first . If it is , and you have eight square faced plastic cover on the front of the ice maker itself that can be removed by un- snapping it, remove it and see if there is a small screw with a spring underneath it or positive or negative arrow's on the unit where the screw is located. Regardless, if there is a screw all by itself turned the screw 1/2 turn
Counterclockwise. this will decrease the amount of time the water valve is open during the ice bin filling cycle.
Just had this same issue repaired yesterday, the defrost element was out allowing the freezer to freeze up stopping the fan which moves the air and in turn causing the upper part of the frezzer to become warm and melt the ice. This is a common problem for the GE profile and I recommend finding a service company cheaper than GE and quit letting GE make more money off their CRAPPY appliances.
Either your water control valve is leaking while off or ice has formed in the fill tube for the ice maker causing the water to spew in directions other than the ice maker or both. A new water control valve may be needed. Part number WR57X10050 Let me know if this helps. Sea Breeze
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Continuous ice production, too much ice in the bucket, ice cubes overflowing the bucket, ice cubes falling behind the bucket or ice lifting the chiller shelf can now be resolved by installing a redesigned feeler arm. The new arm is designed with a slight curve to cycle the icemaker “OFF“ before the cubes overflow the ice bucket. Order part number WR49X10103.
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
