20 Most Recent Maytag MSD2434GE Side by Side Refrigerator Questions & Answers
0answers
0answers
Broken freezer drawer
you can get a new one from a company called e spares on the internet
3/21/2014 9:40:07 PM • Maytag MSD2434GE... • Answered on Mar 21, 2014
Ice maker not making ice
The solenoid that lets water into the ice maker is not working. The ice maker itself can also cause a working solenoid to malfunction.
1/17/2014 4:15:52 AM • Maytag MSD2434GE... • Answered on Jan 17, 2014
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
11/8/2013 12:45:17 AM • Maytag MSD2434GE... • Answered on Nov 08, 2013
Maytag Refrigerator, Vibrating Noise
What is a short time? 5 or 6 secondswould be icemaker fill valve.Tubing in back is a common noise maker ,could be somthing hitting the condenser fan blade.
11/28/2012 1:30:53 AM • Maytag MSD2434GE... • Answered on Nov 28, 2012
Moved my mds2434ge maytag side
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
8/17/2011 6:02:14 PM • Maytag MSD2434GE... • Answered on Aug 17, 2011
The freezer not working , it make a noise for
if the noise is that short sounds like maybe it is possible the compressor relay is bad... if your hearing a click at the end of the noise then most likely you either have a bad compressor relay or the compressor itself has failed.... this unit is common for having this problem and your short post i would say by the description that is what it would be... access the rear of refrigerator and plug it in again after it has been off for at least a hour or so ..there will be a cover at the bottom that can be removed to access the compressor area... plug unit in and place your hand on the compressor and listen if the noise is coming from there then you will need to replace the relay on it....good luck to you..
2/14/2011 3:54:18 AM • Maytag MSD2434GE... • Answered on Feb 14, 2011
My refrigerator has been working fine. Now all of
Here is a tip that I wrote about the reasons why the sides and/or seals could be getting hot on your refrigerator.
Refrigerator Trouble The Outside of Refrigerator Hot
heatman101
1/30/2011 4:08:11 AM • Maytag MSD2434GE... • Answered on Jan 30, 2011
Fridge not cold freezer cold fridge not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1/17/2011 2:15:52 AM • Maytag MSD2434GE... • Answered on Jan 17, 2011
I have a Maytag side by side, MSD2434GEW, about 8
the clicking sound is the compressor trying to start . i belive that you need to reolace the relay start on the compressor . the part that maytag has on ther websight is 12002794 about 34.00 .. mm hope this helps feed back pls ..
12/10/2010 8:53:55 AM • Maytag MSD2434GE... • Answered on Dec 10, 2010
Ice has formed on the floor of freezer
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
9/5/2010 1:25:25 AM • Maytag MSD2434GE... • Answered on Sep 05, 2010
Maytag MSD2434GE Side by Side Refrigerator Logo
48 questions posted
Top Maytag Refrigerators Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
maytag side side msd2434gew about 8
  • Refrigerators
