Replaced the thermocouple,blew out gas lines
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Either getting too much or not enough air flow is what I would check into on this one.
