I dont know the wireing from the mic
SOURCE: I have a cobra 148gtl with 5 pin side plug for
ALLways start with ground. Find ground on radio pin with ohm meter. EVERY thing operates off ground. Once you find ground on radio....solder your ground wire on mike cord to corresponding # on mike jack. Once you have ground on proper pin then all else is elementary......use ohm meter to see which wires are TX and RX on mike.....last wire is audio wire.
SOURCE: Need Cobra 148GTL with Cobra HG M75 pin-out color code
The above wiring combination does not work
SOURCE: i have a cobra hg m73 mic and the wire broke.i dont know the pin color code
it depends on what kind of radio youre using and how many wires are in the mic cord
