To remove the plinth on your AEG FFE62620PM dishwasher, please follow these steps:
Turn off the power supply to the dishwasher by unplugging it or turning off the circuit breaker.
Open the dishwasher door and locate the two screws on the bottom of the plinth. These screws are located on either side of the dishwasher and are usually covered by plastic caps.
Remove the plastic caps and use a screwdriver to unscrew the screws.
Pull the plinth away from the dishwasher to remove it. It may be helpful to have someone hold the dishwasher steady while you do this.
Once the plinth is removed, you should be able to access the base of the dishwasher and any components located there.
If you need to reinstall the plinth, simply reverse the above steps.
Probably a loose or lost bolt connected to main body with a pin that supports the door. Usually the fridge has top and bottom pin hinges for adjustment so the bottom one must the problem. Look around for bolt/screw on the ground. If can't find it you will need to buy one to match from hardware (unscrew matching bolt/screw from other side and match). You may need a short handle screwdriver if space is limited or carefully have someone tilt the fridge to get access -MUST place a wood of block under so it doesn't fall squashing your hand when working under . Use small mirror placed underneath to see where the bolt/screw goes. Replace fittings and adjust height of door so it seals.
Yes, the driver´s door has the master switch for everything. No need to dismount the door panel. Look inside the door grab rail ( which is part of the window switch subpanel)and there is a tiny black plastic cover that hides a single phillips screw. Lift the cosmetic screw cover with a tiny flat screwdriver, there is a slot to insert the screwdriver, to lift it. PARTIALLY, just enough to see the screw.Unscrew it, and the whole subpanel comes out, pulling upwards. The screw plastic cover is very frail, and has a slave strip that attaches it to the bottom, when unscrewing, be very careful not to break it. The subpanel itself has 2 or 3 connectors to handle window / window lock and remote mirror duties. Check that all connectors are plugged in firmly. If they all were attached to begin with, check that the contacts have not rusted.
Your pump is seized, call keurig for a replacement at 866-901-BREW.
If you're out of warranty, the repair instructions are as follows:
1) Unscrew the screws securing the k-cup arm top piece to the frame (look at the top needle, the screws are right by that) 2) Pull out the body piece, unscrew the 2 screws that secure the top cover to the unit. Pry up at the area near those screws to pop the top piece up more. 3) Remove the top cover from the brewer by removing the 4 securing clips (shine a flashlight into the gap, use a long screwdriver to disengage the clips). There is 1 on the left, 1 on the back side left, 1 on the back side right, and 1 on the right. Start on the left. 4) Remove the 2 screws above the LCD and the 1 screw on the opposite side. These secure the back cover to the unit. 5) Remove the bottom metal cover (you do not need to unscrew the rubber feet). 6) Remove the screws that secure the plastic frame to the bottom of the unit, the screws are located around the perimeter of the unit, there are 1 or 2 located in the center of the unit Remove the bottom pump for the water tank. Pry the frame out, be careful of the pump you just unscrewed. 7) Slide the back cover downward, and push it outward. Remove the back cover from the unit, or at least get it out of the way. 8) There is a small pump located on the lower right corner of the unit (underneath the transformer) Remove that, and disassemble it by removing the 3 screws on the bottom, and then the 2 screws located underneath the plastic layers. 9) Wash the pump with isopropyl alcohol, you may need to shake it or manually turn the pin to make it work. Test it using a 12V power supply. 10) Reassemble!
1. Bend or put on back side the appliance and remove the three screws which secure the plinth to the lower part.
2. Remove the filter door
3. Remove two screws
4. Release the plinth
5. Turn it
6. Remove the plinth
Remove left door on copier.( Remove plastic cover left from the door ( 3 screws ), disconnect the wires if you have duplex, unscrew the screw on black plastic tape, with pliers pull up the metal pin wich acts as upper hinge.)
When you removed the door, from left side beaneth the fixing assy you will see smal black cover with one screw, remove it so that you can disconnect the connector of fixing film assy, from the right side of fixing assy, remove the cover ( that is the cover wich is long and covers the door locking mechanism - two screws ) Disconnect the 3 conectors. Unscrew the scres that holds fixing assy left side and right side. Pull towards the fixing assy.
Dismantle it how you see it, but you need to remove the green handle, and remove the axis that have on both side plastic pressure realese pins.
Below is for Whirlpool/Kenmore, u might find it helpful. Some machines have a small trap door on left front bottom, coin trap.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath.The panel will drop and come off.Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.Check your pump too. On some models the filter is located ‘inside’ the big hose from the bottom of the tub.This takes more time to clean.
You don't have to take off the bottom. You need to take off the panel right in front of the screen
1. Pop off the strip in front of the keyboard. 2. Unscrew the 3 screws. 3. pop off the panel that has the startup button on it. 4. Take the keyboard and put in the replacement. 5. To put it back together.
