Turn on down light. Push flame button (red LED flashes but lamps do not lite). Push heater button and turn t-stat clockwise (LED flashes, "spinner" rotates but ember bed lites don't come on) Heater heats up for a little while but fan never spins even though it easily spins pushed.
SOURCE: Oil filled Heater will not turn on and heat.
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
SOURCE: Heat turns off
Sounds like the high limit switch on the heater is kicking off. The flash is the switch shutting off the heating element. The only way to reset it is to turn unit off for about 5 minutes. Possible problems are: 1.) Bad thermostat 2.) blower motor not turning fast enough which means motor is bad.
SOURCE: reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
SOURCE: Laars lite 2 LG or LD Pool Heater- Heater won't stay on
the control module is the problem it allows the heater to come on then turns off power to the gas valve.if you are not getting enough water flow the high limit is turning the heater off then your problem is flow.
SOURCE: Reddy Heater keeps shutting down
I tried to go to www.desatech.com and you cannot buy parts on that site anymore. I can get my Reddy Heater parts at www.masterparts.net.
Hi
If clean light is blinking 7 times then it may be an issue
with heater circuit, door switch or wash pump. If yes then please reset the
power to the dishwasher. After, 5 minutes check if you are still getting the
same error. If yes, then it is a water heating fault. To resolve this error try
pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High
Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi
Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and
then you press the Cancel/Drain button and allow it to completely drain and
reset.
If this doesn't work then it's an issue with the wash pump not pumping the
water past the heater efficiently or due to lack of water to heat. Please make
sure that heater is not open circuited and is heating the water efficiently.
You'll have to check the heater using a multimeter; the meter should read
between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is
fine then make sure water pressure is optimum and fill valve is working
fine.
Hope this helps... Please post back for further assistance.
Daniel
