A
Anonymous Posted on Sep 23, 2014
How do i solve problems by finding equivalent ratios
Carrie put 4 times as much moneyas paul 4:1 paul earned 35.00 how much did carrie get
k24674
Level 3:
  • Office Equip... Master 8,093 Answers
  • Posted on Sep 24, 2014
k24674
Level 3:
Answers
8093
Questions
0
Helped
4675758
Points
21596
Carrie:Paul =4/1 Carrie get (4/1)*35 =4*35.00=
3answers
Are the ratios 4:3 and 20:15 equivalent?
ratios 4:3 and 20:15 are equivalent. If you equate them into fractions it will look like this. 4/3=20/15. if you multiply 4/3 to 5/5 the answer would be 20/15. Therefore, they are equivalent ratios.
2009 mercury 25 hp motor turns over but won't run. new plugs put in. fuel pump IS working.
Hey Paul,
AN internal combustion engine requires three things to run..(assuming all internals are good)
1. A properly timed spark
2. Proper air/fuel ratio
3. Adequate compression >120psi
Eliminate each of these... one at a time.. you WILL find out why its not running..(this is how a professional trouble shoots a non-running engine!!)
What is the equivalent fraction to 0/2?
If we have no pizza, and divided it between you and me, how much do we get? ZERO.
However, you want equivalent fractions to 0/2. To get an equivalent fraction, you multiply the numerator (the number on the top) and the denominator (the number on the bottom) by the same number.
So we can multiply the top and bottom by 2.
0 x 2 = 0
2 x 2 = 4
So an equivalent fraction would be 0/4.
Good luck.
Paul
How do i change a fraction into a ratio that does not have a denominator of 100?
You're on the right track!
920 92 46 23
1000 100 50 25
Now we can't go any further, because 23 is prime.
Good luck.
Paul
How do i do eqivalent ratios
Ratios are like fractions: to make an equivalent ratio you simply multiply both sides of the ratio by the same non-zero number. 1:2 is equivalent to 2:4 (both sides multiplied by 2). 10:12 is equivalent to 5:6 (both sides multiplied by 1/2).
Mrs. Jones lets her students wear fuzzy slippers to school if they earn 30 stickers. She gives them 4 stickers for every week that they have perfect attendance. Kelsie already has 8 stickers. Which i
Let x be the number of future weeks.
8 + 4x >= 30
Solve for x by subtracting 8 from each side and dividing by coefficient in front of variable. Plug answer into original equation to check that it works correctly.
Good luck,
Paul
2helpful
2answers
2helpful
7answers
Ratio and propotion
15 men earns 525
1 man raens 525/15
equals to 35
7 women earns 525
1 women earns 75
so 7 men and 13 women earns 7 *35+13*75=245+975=1220
k24674
ADMIN Andrew
ADMIN Andrew
