I changed the drum unit, developer,and also swap the main pwb or high voltage pwb but the printing/quality is still the same.Also I changed the isu & lsu but still the problem is same.Any advice or solution for that problem is most acceptable.
SOURCE: Degradation of copies produced by Mita ai3010 copier
Please put the copier machine in the horizontally,and check the developer level in the developer station.Check the magnetic roller.If the copy degrade in the normal size (paper is positionly normal) the problem is in the optics section.In this case remove the mirror obturation plates,alligniament,clean the expo lamp.If the copy is degrade in the RS tray you need the check the developer unit,change and alligniament the doctor blade value (0,35mm) and change the drum collars.
SOURCE: The control panel is on but there is nothing display
did u check cable for control panel is it seated well in panel also check cable to other side to where cable goes to board if it,s fine then if u have another tested control panel swap with it hope fully will be fine if not then it would be board of control panel try and let me know
SOURCE: Image Faulty
there are paper guides on either side of the paper in the bypass.make sure thy are nice and snug right next to the paper.
