Sony Playstation 3 (PS3) Console Logo
A
Anonymous Posted on Aug 22, 2014
Install playstation 3
We bought PS3 overseas and we have a compatibility problem. How do I fix it or how to instal it
bri_amesse
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Aug 22, 2014
bri_amesse
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
5660
Points
35
You are stuck buying games from whatever country you bought the PS3 from i.e if it's Japanese you can only play games made in Japan. Hope that helps :)
5 Related Answers
Anonymous
  • 152 Answers
  • Posted on Jan 03, 2008
SOURCE: playstation 2
if you bought your PS2 where you live then you have a region code problem ..Please make sure the Region Code of the software matches that of the North American PlayStation 2 system. Only discs (games and movies) coded with regions "1" or "All" will work on a North American PlayStation 2 computer entertainment system. Consumers residing in the United States or Canada must use a North American PlayStation 2 console in order to view "Region 1" content.
this is same for yours too..
Anonymous
  • 117 Answers
  • Posted on May 10, 2008
SOURCE: Playstation 3 backwards compatibility
It is a 40gb ps3???
Anonymous
  • 359 Answers
  • Posted on Aug 14, 2008
Contact Sony Customer service or take it back to the place you purchased. This is a common malfunction that requires replacement of the PS3.
Sony Cust Service 1-877-253-SONY(7669)
Anonymous
  • 95 Answers
  • Posted on Nov 10, 2008
SOURCE: Playstation 3 HDMI
with redlight on...hold power button for 10-15 secs to reset the HAL registers (HDMI) should beep once..then 5 secs later once again
Anonymous
  • 6784 Answers
  • Posted on Oct 02, 2009
SOURCE: Playstation 3 turns off for every ten seconds and I can't update!
HI. You will need to Clear Any Failed system updates that cause the console to error. Use this procedure to acheive this .
  • With the console off, press and hold the sync up button (the small white one)
  • While holding the sync button press the power button to turn on the console
  • Continue to hold the sync button until the Console has booted up completely.
  • During the boot process the console should clear any failed updates, allowing you to use it normally.
Will not install I have Win 7 64 bit
If you bought a PS3 game, it won't install on a pc, it's meant for the PS3 only.
2answers
How was the msi on the 90's?
Go online to find experts that may guide you step by step.These menonline may show you how to fix your console just as an experienced repairmanwould fix it. Allthese errors can be fixed completely by you without the involvement of anyexternal agency. Disassembly 1.PS3 Disassembly 2. PS3 Controller Disassembly Fix Common Problems Fix to all update related problems 1. The Mystery of the Blinking PlayStation 3 2. The dirt on Blu-ray lens (and how to clean it) 3. PS3 Owners Report Blu-ray Problems After 1.5 Upgrade 4. PS3 Bluetooth Controller Issues 5. Playstation 3 HDMI Problem and Fix! 6. Display/Video Fixes 7. PS3 Error Codes (With related fix) 8. How to Change From HDMI > Composite Easier 9. PS3 3 Beep & Blinking Red Light Fix PS3 Modifications 1. PS3 3.5" SATA HDD Mod 2. Adding IR Remote Control to the Sony PS3 3. PS3 HDD Replacement Mini-Guide 4. USB Flash Memory, USB Hard Drive (External Use) Controller Modifications 1. PS3 Controller Light Mod 2. PS360: Microsoft Controller, Meet Sony Controller 3. PS3 Controller Light Mod 2 4. PS3 Controller Button Contacts, Add extra buttons to the PS3controller Other Modifications 1. Charging Station Headset Mod Blu-Ray 1. Decrypt Blu-Ray Movies with a PS3 WITHOUT keys 2. Blu-Ray Unique Volume Keys 3. Blu-Ray Media Links 4. Play BluRay movies without disk 5. Convert HD-DVD To Blu-ray (works On PS3), No Loss Of Quality Other Media/Video 1. Set up media servers for your PS3 2. Transfer files from PC to PS3 via WmP11/Nero (viaDLNA/MediaServers) 3. How to stream AVI files on PS3 via Tversity 4. Copy music/videos from your iPod to PS3 5. Getting your PS3 to recognize your External Hard Drive 6. How to create a PS3 HD-MPG from HD-TS (Best Result For Below 1.6FW) 7. How to install your game saves 8. Downloading PS3 Game Saves Audio 1. How to connect PS3 to PC speakers Networking 1. How to change from 'NAT type 3' to 'NAT type 2' 2. Make a Lag Switch 3. Who Needs SIMPLE DNS 4. Remote Play On-The-Go Playstation Network 1. PSN Game Sharing Instructions 2. How to download Japanese Demos/Create *** PSN account 3. Create Different Region PSN Accounts 4. View PS3 Store, Download Demos on your PC and install Demos To PS3 5. Play Online And Access Sony Store No Updating 6. View Playstation store on PC Firmware Modifications 1. PS3 Firmware Version Check Bypassed (Linux) 2. PS3 Firmware Version Check Bypassed (Windows) 3. Ettercap Windows 4. PS3 Demonstration Mode "Unlock" Code 5. Use SIMPLEDNS To Bypass The Firmware Check (Windows) 6. How to UPDATE your PS3 Linux 1. How to install Fedora Core 6 Linux for PS3 2. PS3 Linux - The void has been filled...Full install instructionsfor Fedora Core 5 3. PS3 Linux FAQ 4. GUI Kboot 5. Yellow Dog Linux Free Version 6. Yellow Dog Linux 5.0 Installation 7. Partitioning and readying your PS3 for Linux 8. Gentoo 9. Uninstalling Linux 10. Installing YDL+VLC+Mplayer+Snes9x 11. Installing Mplayer on PS3 12. Installing VLC player on PS3 13. Installing "Other OS" on PS3 14. How to get Wi-Fi to work with YDL 15. Set up a Linux UPnP media server w/PS3 support 16. Run Ubuntu Linux 7.04 (Feisty Fawn) on PS3 17. Ubuntu, Kubuntu, Xubuntu, and Edubuntu onto a PlayStation 3 18. Emulate WinXP in PS3 under Linux Downloads 1. Homebrew Loaders 2. Linux 3. Utilities 4. Firmware Updates 5. "Other OS" Bootable Homebrew 6. Drivers 7. Proof-Of-Concept Exploits 8. Game Saves PS2/PS1 on PS3 1. Do your PS2 games look too jaggy on the PS3? Here's a semi-fix... 2. PS3 SWAP to play PS2 and PSX Games! 3. How to play/install to play PS2 backups on PS3 Miscellaneous 1. PS3 Features 2. Finding RAM locations on resistance 3. PS3 Parental Controls How-to 5. PS3 BiOS Flash Diagram Rev 1.0 So,if you have experienced some of the errors in your console, it is not the endof your gaming days, you can fix it. There are many solutions out there if youare willing to do a little research. This guide most possibly willcontain the solution to the problem you have encountered.
Ps3 repair guide Goodluck, and happy gaming.
I lost my biohazard4 game CD key.... Can u Post key to my email ID: [email protected]
I bought a second hand PS3. The gent I bought it off has gone overseas and I am unable to get the password for it. How do I set a new one
If you are referring to the Playstation Network Online password then without his personal details you will not be able to reset that password. However you are able to reset the PS3 so that it clears all information so you yourself can go to playstation.com and create your own account. You can then select Playstation Network on the newly restored PS3 and enter your own details.
Follow these simple steps to clear all Playstation Network account details.WARNING! You will lose any saved game data and other information doing this!!
Step 1. Turn your PS3 onto standby. (Red light on)
Step 2. Press and hold the power button. It will beep when you first press it, beep about 5 seconds later then beep again and switch to standby.
Step 3. Take your finger off the power button but press and hold it again. It will beep as soon as you touch it, beep again 5 seconds later then beep twice quickly. When you hear this take your finger off the power button.
Step 4. The PS3 will ask you to connect a controller via USB and press the PS button. Do this and then a menu will appear.
Step 5. Select option 5 "Restore PS3 system". This will restore your PS3 back to a clean state so you can put your own details in, for example time and date, console name.
Step 6. On your computer goto https://store.playstation.com/accounts/register/beginNewAccountRegistrationFlow.action
There you will be able to create a new Playstation Network account for free. You can then use these account details on your PS3 when you log in to Playstation Network.
Hope this helps
1helpful
Is there anyway of getting older version of ps3 os that is backwards compatible
If I understand your request, backwards compatibility can not be achieved by installing a different version of the PS3 OS.
You have to buy a 20GB, 60GB or 80GB model that supports backward compatibility.
A quick search of Google Products turns up a bunch of backward compatible PS3s for sale.
I bought a scorpio sata 160gb 5.4k 2.5 harddrive for my ps3 instaled it and all i get is a black screen how do i fix
Here is a link for installing a new hard drive very nice pic by pic guide. Check the steps that are described and see if maybe you missed a step on the initial install.
(http://www.gamepro.com/article/features/127009/how-to-swap-out-and-upgrade-a-ps3-hard-drive/)
1helpful
3answers
I have a playstation 3 that will play everything but ps3 games
The best thing is to send it back to Sony and have them repair or replace it for you. I can help you.
MUZU.
1helpful
4answers
PS2 games not working on 80G Platstation 3
Though the ps3 80g is backwards compatible,it does not play back all ps2 games. go to sony's website,i believe they have a list of games that are,and are not compatible.also make sure your ps3 has all the latest software updates.if you have it hooked to the internet im sure it does
Bluray disc wont eject
Nope but you cant play blu ray movies from your region if the ps3 is different region only games are universal meaning played on any console from any region blu ray movies are regional though sorry =S
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
