SOURCE: Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
SOURCE: Ice Maker works but water dispenser does not.
tank can freeze up check timp the tank is in the food compartment at the bottom in the very back
SOURCE: GE GSS25LGMF Water dispenser-no water
Order and install a WR49X10173 water tube heater. It may take 24 hours to then thaw, but it has worked for me on numerous refrigerators. Cost for the part will run about $50.
