Everything else is working fine but i cant get the turntable to work. maybe a loose wire??
Check the drive belt.
Maybe it is broken, detached, distended from lack of use, worn, etc.
Crowley has a video for how to do that on Vimeo here:
https://vimeo.com/25463872 ,
and other support videos here:
https://vimeo.com/user4579188 .
You can find replacement belts, if necessary, on Amazon, eBay, and specialty sites by net searching for: Crosley <YourModelNumber> Turntable Drive Belt .
Check drive belt.
SOURCE: Suitcase Turntable stopped turning
It you hear the motor spin and nothing is moving, the belt could be broken.
SOURCE: BSR turntable arm slides across record
There can be a number of reasons for this.
Have you checked that the stylus tip has not broken off? this is a common cause and will require a new stylus.
SOURCE: Need free owner's manual for a Detrola record player Model KM837
unable to follow what is wrong.
are you talking about the tonearm or a lever at the power switch?
SOURCE: My turntable does not work. Is there a lock ?
Try this - GENTLY move the phono arm to the RIGHT until you hear a
click (of course, do this after you turn on the power via the volume
dial and set the other dial to"phono"). Doing this turns on the
turntable when you haven't used it in awhile. This worked for us, hope
it works for you.
If
it doesn't work, you can check the belt by removing the tiny clip at
the center post and gently lift the turntable platform/tray to peek at
the motor and belt underneath. The pulley is on the right at the 2
o'clock position, the belt should be in contact with it.
SOURCE: Crosley CR66 turntable not turning, belt is fine - motor?
frozen motor maybe or blown interal fusesmaybe,try manualy spinig platter to try an maybe free it up
