20 Most Recent
Crosley Conductor CR73 Turntable Questions & Answers
Its playing the record to fast do i need to change
Unlikely- it might be in the wrong position, but that could be caused by the belt being slack, in which case you would need to replace it. Check the belt is set up right and if it slips out again replace the belt. Otherwise look around inside for another cause. IE faulty power supply to the motor.
Crosley...
Answered
on Jan 14, 2016
Playing records too slowly
It's likely that the belt has moved off where it should be. If the stylus was damage it would slide across the record or cause poor sound. It would not affect the speed unless there was too much pressure on the stylus, but you would feel that as the head of the arm would feel heavy.
Crosley...
Answered
on Jan 14, 2016
Belt routing
Crowley has a video for how to check the drive belt on Vimeo here:
https://vimeo.com/25463872 ,
and other support videos here:
https://vimeo.com/user4579188 .
You can find replacement belts, if necessary, on Amazon, eBay, and specialty sites by net searching for:
Crosley <YourModelNumber> Turntable Drive Belt .
Crosley...
Answered
on Jan 14, 2016
My player drags and changes tempo when the needle is first put on the player. After time it seems to fix itself but would like to remedy this as soon as possible. Can you tell me how to fix this?
Generally it is caused by the cartridge and stylus pressure not being right. At the end of the tone arm (not the cartridge end) you should find a weight. This needs to be adjusted. If there are numbers on it, start by moving it to a lesser number than the current setting. Move this only slightly. Then try a record. The stylus should stay in the groove, not rumble and not drag. It's best done via headphones. If it comes out of the groove too easily move the weight in the other direction and then test. You have to keep doing this till the sound is good. Too much rumble - reduce the weight, jumping out of the groove increase the weight.
There might also be another control called an anti-skate control. This might be be helpful in your case as it will reduce the effect of the arm being pushed into the center of the record. Once again the settings of this control are based on trial and test like before.
If you have had the stylus for some time also you might want to replace it, as stylus that are worn could cause it.
Crosley...
Answered
on Aug 15, 2015
I always get static when adjusting the volume of
sounds like you have a dust build up on your volume switch? buy some electrical contact spray ( aerosol type ) remove the switch/knob........just pull it towards you, remove the knob and spray a bit......not too much and refit the knob and twiddle it about with the power off and then try it? repeat if necessary? good luck.
Crosley...
Answered
on Jan 03, 2014
Cannot open cd area when
There are two likely causes:
- a CD is not located properly in the tray and is causing the drawer to stick. Solution - try to very gently insert a very thin blade at the bottom of the CD tray and prise it open - but don't force it if it won't budge. If that doesn't work try sliding the blade in at the top of the tray to press the CD down.
- If a jammed CD is not the cause then it is likely to be the rubber drive belt that operates the tray has broken - they are not normally accessible so take it to a repair shop
Crosley...
Answered
on Feb 10, 2011
Volume setting is very high
That is unusual, and sounds like a manuf defect. If your unit is still under warranty, I would say send it in. If not, give them a call, and get a quote for repair. Unfortunately, due to the quality and value of these units, it will probably be cheaper to buy a new one.
Crosley...
Answered
on Aug 09, 2008
