20 Most Recent Crosley 0187SST Turntable Questions & Answers
well even tho u just got it, It sounds like a lub problem. Use very light oil on all moving parts. WD 40 only works for a short while since it evaporates. Good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Crosley 0187SST... | Answered on Mar 03, 2018
Type Crosley Model # of your device user manual " into search engine and it will show sites to get manual. In it there might be a way to help you
Crosley 0187SST... | Answered on May 18, 2016
The only thing you can do is clean the record with cleaning fluid. You will find special cleaning fluids for records on Amazon. If the record is warped you can try a weight pressing down on the record. But sadly if a record is warped bad there's no real cure.
Crosley 0187SST... | Answered on Jun 21, 2015
I have a 1956 stereophonic Motorola record player, and it turns off right when I press "on" I noticed that the record speed was 33 1/3 I used 33. Does this make a difference??
/uploads/images/cr79-tone-arm-stops-early-34896944-4-1.jpg
Crosley 0187SST... | Answered on Jan 22, 2015
No, you cannot. Your Crosley will not have the correct line output jacks. Even if it did, although the output level will be fine, you will not have the proper RIAA equalization, making the sound worse, not better.
Crosley 0187SST... | Answered on Dec 11, 2014
The adjustment for auto return position is normally at the tone arm base on the left side under a rubber grommet. Use a flat blade screw driver to move adjustment screw, then test. Keep fine tuning until arm lifts at desired position. Cheers John. Stylus City NZ
Crosley 0187SST... | Answered on Jun 14, 2014
This happened to me tonight. I had the same problem, to activate the player on you need to move it to the right until you hear a click. If you don't do it it won't start. Even if all the power is on. This should fix everything!
Crosley 0187SST... | Answered on Apr 20, 2014
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Crosley 0187SST... | Answered on Mar 14, 2014
You can contact the Crosley website and they should sort out the problem you have, as the machine is under warranty.
Crosley 0187SST... | Answered on Mar 07, 2014
Hi, most likely the belt has come off or is stretched. Cheers John. Styluscity
Crosley 0187SST... | Answered on Mar 05, 2014
When the arm moves it pushes on a contact switch. It seems that this contact switch is simply out of place, so needs adjusting.
Crosley 0187SST... | Answered on Feb 01, 2014
I rather suspect that the problem is in the power supply section to the motor. If the motor is a small voltage type (9 to 12 volt) it will eithier have a control on it, or on the power supply board that will do that. But it will probably be something on the PC board that is causing the problem (often an IC). Trace the wires from the motor to the PC board and you might see the cause! If you have a voltmeter check what's going to the motor too! If it says 12 on the motor and it's getting 15! you know it's the supply. Otherwise it's the motor if the volts are low.
Crosley 0187SST... | Answered on May 24, 2013
You need to measure the diameter and thickness of the belt in mm. Please make a note of how the belt fits before removing it. You can search for the belt by putting the measurements into Google they don't have to be spot on!
Crosley 0187SST... | Answered on May 19, 2013
Crosley 0187SST Turntable Logo
Popular Tags
64 questions posted
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Marmorstein
Level 1 Expert
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Audio Players & Recorders
Most Popular Question
crosley 6005a in turntable mode sound
  • Audio Players & Recorders
