SOURCE: No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
SOURCE: WHY DOES THE WATER WILL NOT DISPENSE WHEN LEVER PUSH IN
I think your water dispenser switch is broken behind the area where you press your cup to get water. Go tom site below and enter the model HSS25GFPAWW into model search feature and it takes you to a photo of the switch #72 in photo The part number is different WR23X10224 I could also be mwrong but if you need to contact me my email is [email protected] http://servicepartstec.blogspot.com/ <site
SOURCE: ice dispenser not dispensing ice or water
The tube that supplies water to the tray of the ice maker,may have frozen solid. unclog u should be good
SOURCE: The water dispenser stopped dispensing.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the water line in the door is frozen , GE has a dispensor heater which comes with instructions to install . Pt # WR49X10173 .
