20 Most Recent Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Questions & Answers
Water is frozen inside the water tube that runs inside your freezer door. If you empty out the food in the door, you can use a hair dryer on medium heat to warm the frozen piece so it loosens enough the dispense out. Every 5 minutes, close the door and check if water dispenses. It takes between 15-30 minutes. GE makes a dispenser water tube heater that attaches to the top of the dispenser tube to prevent frozen tubes. The part is WR49X10173. Check to make sure it is compatible with your refrigerator. Amazon and Walmart.com sells the part. Good luck!
Hotpoint... • Answered on May 08, 2017
Self Diagnostics To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode. To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests. For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test. For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test. When testing has been completed, do one of the following things: • Enter code 1 5 to completely reset the system. • Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically. • Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in. Test mode will terminate automatically after 15 minutes of inactivity. Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Hotpoint... • Answered on Mar 24, 2015
Check the water tank in the refrigerator section.
Hotpoint... • Answered on Jul 22, 2014
pipe will be creased try it with the door open and see if you get water through then if not then it will be badly creased blocked goodluck
Hotpoint... • Answered on May 30, 2014
This is a thermistor. It depends where it is located how you would be changing it but the generic answer would be unplug the refrigerator. remove the old one leaving some of the leads from the old one before you cut the wires. so you have some wire to work with. Using small wire nuts or crimp connectors wire the new thermistor to the old leads from the old thermistor it is best to either fill the wire connectors or crimp connectores wirh silicone sealant or tape the connectors with electrical tape to prevent water from entering the connections. Put the thermistor into position and away you go.
Hotpoint... • Answered on Apr 13, 2014
no cooling at all on both sides? if thats the case do you have power to the unit ..lights on fans running then your compressor is not working check the starting components and hear if the compressor works also check the controls are they on or off? good luck..
Hotpoint... • Answered on Dec 08, 2013
In the freezer is a small fan the blows the freezer air into the fridge section. Either there is ice buildup and the fan blade is rubbing on it or the motor bearings are bad.You will need to remove the rear freezer panel to find out and/or replace the fan. They run from $25 to $60
Hotpoint... • Answered on Nov 05, 2013
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Hotpoint... • Answered on Aug 20, 2012
Is it not defrosting, or defrosting and re-freezing the meltwater as ice? Check drain clear. Further checks are 1) defrost timer 2) defrost heater 3) defrost klixon
Hotpoint... • Answered on Aug 08, 2012
have you changed the filter? if so try a complete defrost of machine and pull the inlet line from back of icemaker and make sure there is no calcium lime deposits restricting water flow
Hotpoint... • Answered on Jul 04, 2012
the fan is wired with a circuit board turn off and reserch parts on hotpoint ,
Hotpoint... • Answered on Mar 20, 2012
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
132 questions posted
Top Hotpoint Refrigerators Experts
Dan Webster
Dan Webster
jdthefixer
Michael Thomas
Michael Thomas
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Refrigerators
Most Popular Question
no water from dispenser
  • Refrigerators
