20 Most Recent GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW Questions & Answers
What do I set my fridge to the freezer goes 1027 the fridge goes 34 to 38
GE Profile... | Answered on Jul 10, 2020
Sounds like you have a bad water intake valve
GE Profile... | Answered on Jul 12, 2017
There is really nothing to be done.
GE Profile... | Answered on Jul 10, 2017
The dispenser bulb looks similar to a c7 christmas bulb or night light bulb but they are not the same. The dispenser bulb on some are 6 volt and some are 12 volt. The night light bulbs are 120 volt and will light very dim. Make sure you got the correct bulb from an appliance part dealer. They will need your model number of the fridge. Or check on line parts stores like www.vvapplianceparts.com.
GE Profile... | Answered on Mar 07, 2016
yes, dust build-up will cause over-heating and burn-out the defroster circuit-board....you will need to have serviced to see which control board failed for sure. Keep those vents clear....every couple of months vacuum them.
Tallon41
GE Profile... | Answered on Aug 30, 2015
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
GE Profile... | Answered on Jun 27, 2015
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
GE Profile... | Answered on Mar 14, 2015
if wi would repace the main board and also the fan..both are simple to replace..
GE Profile... | Answered on Oct 15, 2014
Refrigerators Logo
275 questions posted
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
fix dim light bulb ice dispenser
  • Refrigerators
