USB port has dislodged inside tom tom unit so the charger will not connect to it to charge the battery. How can this be repaired? Can the unit be opened?
SOURCE: tom tom is not working
1: Make a full back up of your SD Card.
2: Delete your SD Card.
3: Install the latest update to your Device, you will need to log in to the Tomtom website, select on the support page, select on the 1st question ' Update , follow the instructions on how to download and install the Update on to your Device
4: Re-install your Backup. The only Folders that you will need to re-install are the Voice, Map and Zip Folders.
SOURCE: The TMC was working fine on my tom tom ONE XL but
Try resetting the Tom Tom.
To do this: Stick the end of a paperclip into the reset hole in the bottom of the receiver. See your manual for the details on this.
This fault is often caused by unplugging the receiver from the navigator before turning the navigator off.
SOURCE: I have a Tom Tom
Use a paperclip in the reset hole in the bottom of the navigator. See the manual for more details on resetting.
Often this problem is caused by unplugging from the antenna while the navigator is still turned on.
SOURCE: having difficulty in connecting with tom tom to
It's difficult to tell from your brief question exactly what you need. Could you please tell us what you're doing, what you're seeing, and what you expected to see instead?
In general: Try downloading and installing the Tom Tom Home software, then plugging your navigator into a USB port on your computer.
Here's where to get the Tom Tom Home software:
http://www.tomtom.com/services/service.php?id=16&tab=87
SOURCE: CANNOT ACCESS TOM TOM TRAFFIC
If you're using a RDS-TMC, then you don't need to go through Tom Tom Traffic. The traffic bar should show up on the right-hand side of the screen, and you're good to go.
If that bar isn't showing up, here's what to do:
Reset the navigator (use a paperclip in the hole on the bottom of the unit). Plug the RDS-TMC antenna into the navigtor. Plug the car charger cable into the RDS-TMC antenna. Turn on the Tom Tom.
Is there a traffic information bar now?
