20 Most Recent Tomtom GO 510 GPS Receiver Questions & Answers
10answers
Battery replacement for TomTom 710
I have found a trick for those bad battery ,but you lose your waranty
you need to open your tomtom , behind the screen you wil find the battery(for the Go 710 it is an 3.7 V ,2400mAh,samsung ICR18650-24)
you find 3 wires : red, black,yellow cut them of at the half of the wire size
, then cut off your car loader wire (tomtom)(5v), you will see again 3 wires inside :red,black,white
connect the red with red, black with black, white with yellow
(the best thing is to make a little hole in the cover to pass the wire, so it will be beter for closing the all thing)
I did it and it works pretty fine ,I had save 30 dollars ;) :D
I did in approximatly 30 min
remember you will have no battery any more and no waranty of tomtom!
It only whorks then with your car loader tomtom
7/9/2016 1:13:34 PM • Tomtom GO 510... • Answered on Jul 09, 2016
My gps will not recognise my sd card or turn on
Try the clear flash utility. It worked for me. Martin
4/30/2015 2:54:08 AM • Tomtom GO 510... • Answered on Apr 30, 2015
0answers
Can not find spacer button to put in code GO 510
read your other post
4/14/2014 12:16:17 PM • Tomtom GO 510... • Answered on Apr 14, 2014
Is there a reset button on a go 510 live
Yes, the reset button is actually a small hole at the base/bottom of the unit. You'll want to use a straightened-out paper clip or something similar to put into the hole and press it for a few seconds (until the unit powers off) .... after you've fully charged your battery.
10/27/2013 7:11:01 AM • Tomtom GO 510... • Answered on Oct 27, 2013
2answers
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
7/31/2012 12:18:45 AM • Tomtom GO 510... • Answered on Jul 31, 2012
MY TOMTOM GPS NEED TO BE TO RESET
I will advice you reset the unit, this might help fix the abnormality with the white screen problem. follow these procedure to reset your tom tom gps.
Make sure your battery is charged before you begin. TomTom suggested allowing your device to charge for at least 2 hours before resetting it. Remove your device's SD card from the card slot.
Find the "Reset" pinhole button on the bottom of the device.
Hold the "Reset" button down for 10 to 15 seconds or until your device resets itself. You will need a flattened paperclip or another small metal object to reach inside the pinhole.
Power the TomTom back on and insert your SD Card. You have now reset your TomTom gps and this should fix the white screen problem.
Take care.
2/15/2012 12:32:28 PM • Tomtom GO 510... • Answered on Feb 15, 2012
0answers
My tomtom wont turn on
If your tom tom does not seem to charge, then there seem to be a problem somewhere in the unit. You need to run a check on the battery, the charger and the device itself.
First test the charger by trying to use it on another device, if it charges the device, then it is working perfectly fine, but if it does not, then it means the charger is bad and need to be replace with a new one.
Test the battery also, by inserting it into another device, plug it with a well tested charger for about 2 hours to see if it will hold a charge. If it does turn on, then it means your battery is intact, but if it does not, then it means the battery is dead and cannot hold a charge. And the solution to that is for you to replace the battery.
Test the device by inserting a well tested battery in it, and connecting a well tested charger on to it also, if it does not charge, then it means there is a problem with the connection port or something with the device.
After carrying out these tests, you will be able to detect the problem and how to solve it.
I hope this information was helpful to you.
1/6/2011 10:37:57 PM • Tomtom GO 510... • Answered on Jan 06, 2011
Hi i get the greeenlight on charging but then
if the unit has been unplugged for a while and the battery has gone flat, you will need to hold the on button for a few seconds to re start it. After that , it will be ok. Just a short push of the button as usual
10/6/2010 5:43:28 AM • Tomtom GO 510... • Answered on Oct 06, 2010
My tom tom has a blank screen but has the green
Hi, there is a small reset button you can push with a pin. Revived my "dead" 910...
10/5/2010 10:43:12 AM • Tomtom GO 510... • Answered on Oct 05, 2010
2answers
My tomtom led light comes on when on charge, but
U need a new battery plain and simple.
7/19/2010 9:12:01 PM • Tomtom GO 510... • Answered on Jul 19, 2010
Tomtom 510 - packed up
try re setting the TomTom, reset button is founded on the bottom underneath where the docking mount connect, hold down for 15 seconds, then press the little button on the top on the right side while turning on. worked for me
6/13/2010 3:20:55 AM • Tomtom GO 510... • Answered on Jun 13, 2010
My tom tom 510 turns off after 30mins
Hello :
This is a battery problem . Replace the battery and problem will be solved .
If that didn't solve the problem , then the battery base could be isolated by some stuff . By base I mean where the battery set . Clean the points where the battery and the device connect with a q-tip and alcohol containing liquid.
PLEASE RATE !
4/16/2010 2:07:28 PM • Tomtom GO 510... • Answered on Apr 16, 2010
My tomtom only gives Guam locations
Your problem might be that the GPS can't get a lock on the satellites and it doesn't know in which part of the world it is.
I suggest you download the latest updates and QuickFix, then leave the unti close to a windows (even if you are indoors). The unit should be able to getn afix on the GPS satellites in less than 15 minutes.
Please, let me know if you need more detailed instructions.
3/30/2010 9:36:07 PM • Tomtom GO 510... • Answered on Mar 30, 2010
Have tried to do an upgrade on my 510 but all that
Remove sd card & replace
3/9/2010 11:20:59 PM • Tomtom GO 510... • Answered on Mar 09, 2010
My tom tom 510 wil turn off after a 10/15 secounds
Ok, try a replacement battery. They often cause this problem.
2/26/2010 7:52:45 PM • Tomtom GO 510... • Answered on Feb 26, 2010
The battery on my Tomtom Go 510 has failed. How do
tomtom says it is not possible to change the battery. you can only send it to tomtom during warrantyperiod. the say there is always a possibility to run tomtom on dc, home loader, car loader or dockingstation or pc. sorry.
2/17/2010 5:59:10 PM • Tomtom GO 510... • Answered on Feb 17, 2010
GPS Logo
Popular Tags
149 questions posted
Top Tomtom GPS Experts
Marvin
Marvin
David Shaub
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
View Most Popular
GO Tomtom
  • GO Tomtom
Most Popular Question
reset button go 510 live
  • GPS
