SOURCE: MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power
Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
SOURCE: maytag mah5500bww washer
Unplug the unit for 5 minutes to reset the control. if the control continues to remain locked, this will confirm board failuer and, you will need to replace this control board.
SOURCE: Maytag Neptune MAH5500BWW fills with water but
It is possible for the water level/pressure switch to go bad. Other cause would be a faulty selector switch. You can test either one with an ohmmeter to see if it is faulty.
You can also check out this info (copy and paste in internet address bar under a new tab)
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
SOURCE: WHEN YOU PUSH THE ELECTRONIC BUTTONS, THE MACHINE
Replace door lock assembly. Serial number is needed for the correct part number.
