SOURCE: I need instruction for a vulcan ducted gas heater
ineed to unlock my sim card said puk code and idk
SOURCE: Ive got a Vulcan Gas dusted Heating system -
Possibly a bad thermocouple or whatever is sensing the flame. If its a flame rod you can clean it with steel wool. Let me know what you find.
SOURCE: we have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
SOURCE: my vulcan ducted heating/cooling isnt working the
YES THERE IS MEANT TO BE A PILOT LIGHT,WHERE IS THE UNIT LOCATED ?
SOURCE: Vulcan ducted heating system 530 E (5 years old)
You have to recode the remote to the heater if the batteries have been removed for more than 3 minutes. On the comfort control will the remote is in a off state turn the heater off at the power.
While off press and hold the up button and the on/off until code appears then release buttons and turn the power back on to the heater.
When code disappears from the remote turn on the remote set the temp higher than current temp and combustion fan should start up then heater will fire up.
If not repeat process as they are easily corrupted by other remotes.
Download control manual from - http://www.bonaire.com.au/support/documentation/owner/default.aspx
Set / check fan speed or it may overheat.
