I was able to fix my Pyrox ducted gas heater (flashing between HC01 and F08 by pressing the reset button on the main PCB located in the main heating unit.
The reset button is located next to a set of indicator led's. It's easy to get to by just removing the covering shroud.
Posted on Oct 27, 2014
SOURCE: VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Posted on Jan 05, 2010
SOURCE: My bonaire vulcan ducted heating
Does the green power switch light when the Start
key is pressed?
No: - Is door completely closed? Door switch may
be interrupting power.
Yes:- Check the fuses on the controller PCB
- Check heating element plates for continuity
Hope that helps.........
Posted on Jul 08, 2008
SOURCE: control panel lights constantly flashing
You should have a dedicated line that feeds the equipment power look at your main electrical panel or search around your equipment for a pull out disconnect switch or sometimes they will wire it to a light switch. by shutting down the main power and turning it back on it should reset anything.
Posted on Jan 05, 2009
SOURCE: Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Posted on Jan 29, 2009
Jun 20, 2016 | Heating & Cooling
Mar 10, 2015 | Vulcan Heating & Cooling
May 10, 2014 | Heating & Cooling
May 09, 2014 | Heating & Cooling
Dec 31, 2009 | Heating & Cooling
Sep 08, 2009 | Heating & Cooling
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Feb 16, 2018 | Heating & Cooling
1,281 people viewed this question
