Maytag MSD2454G Side by Side Refrigerator Logo
A
Anonymous Posted on Jun 21, 2014
Maytag refrigerator will not dispense water - Maytag MSD2454G Side by Side Refrigerator
Bill Kendrick
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jun 22, 2014
Bill Kendrick
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
Helped
4852
Points
15
When you use a glass and try to get water, if you hear a click or buzzing sound, the water switch is working, if not it is an electrical problem, the water solenoid valve could be bad, or the switch. One other thing to check is the filter on the water line. Some have an extra filter. Turn the water off, disconnect the filter and see if you can blow through the filter. There is a screen filter just before the water valve check it to.
5 Related Answers
Anonymous
  • 828 Answers
  • Posted on Dec 02, 2008
SOURCE: Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on May 31, 2009
SOURCE: My Maytag side by side refrigerator's water dispenser won't stop
Below is a picture of the fountain parts. I believe the controls inside the fountain are defective and will need replaced. Temporarily disconnect the control valve to the Fountain control plug this will allow the ice maker to continue to work. Let me know if you need more help and assistance to solve this problem. Below is a link to my site, email and a photo of the parts. Thank You, Sea Breeze [email protected]
http://servicepartstec.blogspot.com/
http://www.servicematters.com/maytag_library/docs/16010154.pdf
Anonymous
  • Posted on Mar 11, 2010
SOURCE: My maytag MSD2556ae side by side refrigerator water/ice dispenser
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
jturcotte
Jeffrey Turcotte
  • 8991 Answers
  • Posted on Jan 09, 2011
SOURCE: I just replaced the water
Hi, there is a micro-switch at the filter which shuts off the supply and operation while the filter is out of the unit. That switch is still open, so the dispenser thinks you are still replacing the filter. Try taking the filter out and putting it back in. Make sure any locking mechanism is fully engaged. In the meantime, I will see if I can find the service manual for your unit.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Apr 19, 2011
SOURCE: water dispenser will not stop
One of two things that I can think of and one being the switch being broken in the on position where you press the cup to fill. Part Mumber=> 61005520 Item 11 or position 11 in the large photo below. Here is the water control valve that goes to the model; with water filter=> 12001892 Water Control Valve for Filter
It also can be in the stuck on position
12001892 Water Inlet Valve
Click Here for Large View of Fountain Parts=> MSD2756GES Maytag Fountain Parts If you have any questions please ask, Thanks, Sea Breeze
2helpful
My Maytag MZD2766GE dispenses water but does not make ice
check water valve, also your water line for ice maker could be frosted that happen always, but reason is bad water valve....
appliancesrepairla.com
The switch on Maytag water and ice dispenser hangs
Need to enquire from the agents if that dispenser switch is available as a spare part. If so, switch off and strip carefully as logic shows you.
7helpful
3answers
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
My maytag water dispenser not dispensing water
I am sorry I can not find a model listed Maytag Email me with the correct model or visit my site to see where to look for the model numbers.email is [email protected] is below, Thanks, Sea Breezehttp://servicepartstec.blogspot.com/
1helpful
My refrigerator water dispener is dispensing jelly like stuff !
run it until the water comes out clear and replace the filter trice.
I have a Maytag side by side refrigerator and lost my manual. How do I remove the inside water filter cartridge, which rotates either direction but does not easily come off?
first shut of trhe water and then let the pressure off of the line by openoing up the water dispenser . then turn it counter clockwose and then it sjhould come right off
NEW MAYTAG MSD2652KGW 26 CU FT SIDE BY SIDE
disconect water line and make sure you have water pressure.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
