Vtech V.reader Animated E-book System Logo
A
Anonymous Posted on Jun 21, 2014
What happens if i don't have a SD card - Vtech V.reader Animated E-book System
1helpful
My Pantech sd card reader is not working
I don't know what machine you are using or the SD device GBs. Older machines sometimes do not read any SD over 2GBs. That said, there may be updated drivers for your machine and devices. Could be the file format isn't compatible. Hard to say with little info to work from.
D60 has SD card full message but the SD card is brand new and formatted.
Have you tried using it in another device that reads/writes SD cards?
It's possible it is a counterfeit SD card. Some counterfeit cards don't work or are not the true capacity. If it it a name brand like SanDisk it will have a serial number. The counterfeit ones typically don't have serial numbers.
Was having problems with mini SD card in my HTC Desire S as it kept unmounting. Following advice from work colleagues and forums, I transferred all my stored memory from the mini SD card to my laptop
I don't think you lost your pictures. Same thing happened to my phone. I brought it to the HTC Service Center and they upgraded the software. I suggest you take it to the nearest HTC Service Center so the problem can be resolved.
My phone keeps telling me that my SD card has been removed but it hasn't been. I've tried taking it out and putting it back in but it keeps telling me the same thing
maybe because your phone don't recognize your SD card anymore. try to put your SD card to other phone and try if the other phone recognize your SD card, if the other phone don't recognize your SD card, the problem is in your SD card. you should buy a new SD card if that's the case. Also try to put a different SD card on your phone and you'll see your phone will recognize the different SD card.
Kindly rate this post. Thank you for your question and I hope I help you a lot.
WHERE DO I PUT THE SD ADAPTER
Hello.
You don't need the SD adapter in your mobile phone. You may use it by inserting the micro SD card into the SD adapter, then insert the SD card adapter in a "SD card reader" and use it in a USB slot in your computer to access files from your "micro SD card".
I hope this helped you.
Thanks for using Fixya!
Please rate my answer.
DMC-zs10 records on internal memory - not on SD card
Hello bro..
Do you check your SD card? It is work ?
My solution:
1. Off Lumix camera.Until LCD was off. Press center of card to remove it.
2. Use card reader to connect your SD card to pc/netbook/laptop..
3. Check full capacity for SD card, it is empty(zero) or have it their mount.
4. If empty (full,used,free is zero) ,try reinsert card again and don' t touch the terminal.
5. If still empty, that mean, your SD card was corrupted.
6. If not empty, backup all data in SD card.
7. Format the SD card using FAT32.
8. Checking Disk.
9.Insert back to camera, and format SD card using camera menu.
10. Take picture. and see if save on SD card or not. comment back here. if succes or not.
11. Don't use any battery except original from panasonic. It will affected to product.
12. Don't remove battery or card before lcd was off light.
Jul 24, 2011 • Cameras
1helpful
My polaroid dvf 130 camcorder won't connect to my computer.the software it came with says it doesnt need a driver since I have windows xp what should I do?
this is what i did, and it worked perfectly. go out and get a sd card * any gig u want* as soon as u put the sd card into the camera, FORMAT IT!!!!. do that before u do anything else. don't format it on ur pc or laptop. format it on the camera. if u do that it will work perfectly. i don't know why it wasn't in the manual to format sd card first. but if u try to take pics first, that will mess up the entire system and u will be assed out a sd card. it took me 3 sd cards to figure this out. the cards worked fine but not in the camera. then i formatted it on the camera first and it works fine. the other sd cards i use for other things, i won't discard them but they won't work in the cam. but remember again GET NEW SD CARD AND FORMAT THE CARD IN THE CAMERA FIRST.
2helpful
2answers
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
Top Vtech Toys Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Vtech Toy Expert? Answer questions, earn points and help others
