Question about Nikon D60 Digital Camera
D60 has SD card full message but the SD card is brand new and formatted.
I have used 3 different SD cards, all 1 GB but after 5 pictures taken on auto setting, the SD card reads full. Played with the settings as adjusting image size and quality, it did not help.
Posted by Beryl Young on
Bill
    New Friend:
  • 32 Answers
Have you tried using it in another device that reads/writes SD cards?
It's possible it is a counterfeit SD card. Some counterfeit cards don't work or are not the true capacity. If it it a name brand like SanDisk it will have a serial number. The counterfeit ones typically don't have serial numbers.
Posted on Sep 02, 2012
5 Related Answers
Inky
Inky Fingers
  • 705 Answers
SOURCE: Camera read CF card, but cannot see on USB or other media
You can connect the camera to the computer via a USB cable and use the camera as the card reader. It will show up as a mass storage device. You should then be able to copy the images to your PC and format the card once recovered.
Posted on Sep 17, 2007
Anonymous
SOURCE: Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Posted on Jun 20, 2009
Steve5
Steve Grezoux
  • 423 Answers
SOURCE: I have the Nikon D60 - Ive taken sport/action pictures
The main difference between the two shooting conditions is the amount of light you have to work with. For the indoor action shots, set the ISO setting to the highest available through the menu (1600 ISO) to maximize the ability of the camera to work with the diminished light. The other (but more expensive) way to achieve better indoor shots is with the use of a "faster" lens, ie one with a lower maximum f stop number (f2.8 is faster than f3.5, for instance). Also ensure you are shooting with your lens at its widest f stop setting (lowest number).
Posted on Jul 26, 2009
Anonymous
SOURCE: Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Posted on Aug 24, 2009
Anonymous
SOURCE: New 4GB CF card for E5400, camera gives 'out of memory' message
So far as I am aware, the 5400 will support only up to 2GB cards. As to the firmware upgrade you mention, I don't recall that that has any bearing on the max. card capacity; but it's worth doing for the RAW format support (for me, at least). Cheers and good shooting. Davo, Tas.
Posted on Oct 25, 2009
I have a Polaroid i1032 10.0 megapixel camera. the user guide says that i can use up to a 1 gb SD memory card. I've used a 2 gb SD card and it works fine. My question is can I use SDHC cards 2 gb, 4 gb, 8...
At the time your camera was made, 1GB was the max size standard SD card. Then along came 2GB standard SD, but this card also used the same format as previous cards, so yes it also worked in your camera. Now SDHC is a very different format with different file handling (although externally it looks exactly the same). I'm sorry to say, it is very unlikely that SDHC will work with your camera. Here on Fixya you'll see many folks asking why the brand new card they just bought doesn't work with their older camera. 9 time out of 10, this is the reason why.
Mar 22, 2011 | Polaroid i1032 Digital Camera
Camera will not read memory card
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 01, 2010 | Kodak EasyShare DX7590 Digital Camera
I have the kodak c310 and have tried all the following 128MB 256 MB and 2g none will format and gives file error why?
Your camera is only supporting SD/MMC Cards (up to 1 GB only)
The cards that you currently have might be faulty.
Jan 01, 2010 | Kodak EasyShare C310 Digital Camera
I put a new memory card in our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 1 GB)
1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
Dec 25, 2009 | Kodak EasyShare C330 Digital Camera
Memory Error Message
There is a white switch on the side of those sticks, and make sure it is not in write protected mode. If that doesn't work, I am sorry to say that stick might of went bad. Before giving up I would take to a professional film place and have them take a look to see if they can get them off w/o formatting.
Nov 21, 2009 | Lexar Professional High-Speed 2GB Secure...
Jul 10, 2009 | Nikon D60 Digital Camera
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
New 2 GB Memory cards say cards full when installed
The SD card may have to be reformated. You should do this in the camera you want to use the SD card with. Do not format the card with your computer.
In you manual or on the menu of your camera there is a "Format" procedure. follow that and your camera will work again (REMEMBER) if you have images on the SD card down load them before you format the card.
Once you down load the images from your camera you should reformat the card to clear it in order to shoot more images.
Mar 20, 2009 | Kodak EasyShare C330 Digital Camera
Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Nov 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Nikon D60 Digital Camera Logo
543 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Nikon Camera Expert? Answer questions, earn points and help others
