20 Most Recent Vtech Tote n Go Laptop Plus Questions & Answers
3answers
Is it possible to get a new instruction manual for
Try this link to get the manual. www.vtechkids.com/_f/_pw/_manual/Tote-n-Go_laptop.pdf
1/28/2015 4:47:31 AM • Vtech Tote n Go... • Answered on Jan 28, 2015
Mouse stopped working
My daughter's Vtec laptop had the same problem. The black wire in the base of the mouse had broken off and had to be re soldered. To open the mouse pad remove the four rubber feet under the mouse pad. Use a small screwdriver to remove the four small screws and then lift off the cover. Check all the wires to see if any are loose or broken. There are two small circuit boards inside. The black wire I mentioned connects to the smallest circuit board and the solder connection is on the underside of the board.
7/6/2014 1:56:21 PM • Vtech Tote n Go... • Answered on Jul 06, 2014
Tote n Go laptop, mouse click not recognized
It is very likely one of the wires came loose inside the mouse itself. There are 4 black foot pads on the bottom of the mouse. With the batteries removed, pry off the four feet and remove those four screws. You will see two tiny brown wires that correspond to the mouse button.
Examine these two smaller brown wires and ensure they are not loose or have become disconnected from the small computer chip inside. The two smaller brown wires are on the interior of the chip and should be soldered to the board, opposite a larger brown wire and a larger white wire. The two larger wires, brown and white go back into the main cable that connects inside the laptop.
If these four wires appear to be intact, the next step would be to remove the two larger screws in the central blue piece with two larger holes on either side. This will release the mouse from the base. Examine the two solder points where the two brown wires are connected for any breaks. If these look good, there are two more screws that hold this chip in place. remove them and examine the button of the mouse.
Many others have found the actual push button under the mouse fails. This blog entry explains how he fixed the mouse button: fangletronics.blogspot.com
If you need further help, send a request to: kjhenseler [at] gmail [dot] com
7/6/2014 1:52:36 PM • Vtech Tote n Go... • Answered on Jul 06, 2014
0answers
2answers
Need replacement Vtech mouse
I can't tell for sure but it looks like it connects right o the machine and may not be able to be replaced. Have you tried eBay or contacting Vtech?
3/23/2013 6:41:27 PM • Vtech Tote n Go... • Answered on Mar 23, 2013
0answers
Volume not working
Hi! Did anyone accidentally dropped the laptop? The speakers of these toy laptops are very flimsy in its construction. If you can open up the toy, you can fix the speakers (actually there is only one speaker). Take out the phillips screws under the unit and open it up. You may see that the speaker is not in it's place or it broke into two. Don't worry though, you can still put them back together (carefully). You may apply a small amount of glue on the speaker's edge to prevent the speaker from breaking apart again in case the toy accidentally falls (again). Hope I helped solved your problem. Good day.
4/7/2011 6:30:28 PM • Vtech Tote n Go... • Answered on Apr 07, 2011
I need a manual on how to work the vtech tote and
I suggtes check, downaload and save visiting this LINK by
- vTech Tote n Go Laptop 2009 - User Manual
- vTech Tote n Go Laptop 2003 - User Manual
Also, if you visit this link by vtechkids.com can find about this and other products.
I hope this help; remember to rate this answer.
10/2/2010 11:25:38 AM • Vtech Tote n Go... • Answered on Oct 02, 2010
I need the instructions for vtech laptop
http://www.vtechkids.com/support_manuals.cfm?browseletter=T
7/19/2010 5:48:30 PM • Vtech Tote n Go... • Answered on Jul 19, 2010
Toy computer
http://www.vtechkids.com/_f/_pw/_manual/Tote-n-Go_Laptop.pdf
http://www.vtechkids.com/_f/_pw/_manual/Tote%20and%20Go%20Laptop-New%202009.pdf
7/19/2010 5:44:03 PM • Vtech Tote n Go... • Answered on Jul 19, 2010
Vtech Tote n Go Laptop Plus Logo
28 questions posted
Top Vtech Toys Experts
tina gallow
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Vtech Toy Expert? Answer questions, earn points and help others
View Most Popular
Vtech Toys
  • Vtech Toys
Most Popular Question
need manual work vtech tote
  • Toys
