LG 42LB1DRA 42 in. LCD Television Logo
A
Anonymous Posted on May 31, 2014
What is the service menu code for LG 42LB1DRA?
Need to do an installer adjustment to set white balance.
2 Related Answers
Anonymous
  • 14553 Answers
  • Posted on Nov 05, 2012
SOURCE: service menu lg 37lh260h
your best and maybe only hope is to call the hotel unit for LG (not part of the main unit) to see if they will help or refuse you.
Anonymous
  • Posted on Dec 16, 2012
SOURCE: How do I get into the service menu of my
You can get an rca rc807-b universal remote control. Remote programming code is 009 for that TV. After programming the remote to the tv, You need to press L2 on the universal remote to get in to service menu options. Password is 0000. Risk is yours!!!
Menu segreto hannspree hsg1113
http://translate.google.com
Secret service menu Hannspree HSG1113
https://electronicshelponline.blogspot.com/2015/03/hannspree-lcd-tv-how-to-enter-service.html
Possible menu - Quoting from link above:
SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz)
* In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode.
* To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1)
1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode.
TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS
WHITE BALANCE ADJUSTMENT
1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ??
to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3]
Click on the Pictures to Zoom In
BRIGHTNESS ADJUSTMENT
1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV)
ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options
3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3]
YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT
Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc.
WHITE BALANCE ADJUSTMENT OF Component
1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit.
WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ??
to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
tip
SERVICE MODE AND ERROR CODES CHECK
When pictures are taken out side they come out pink
Your White Balance may need adjusting - try looking in the menu system for White Balance, then set it to AWB (Average White Balance) or an appropriate outdoor setting (Sunlight, Shade, Cloudy etc). The manual should help if you are stuck.
Dec 14, 2015 • Cameras
Is it possible to turn off the white balance in a Sony Cybershot DSC H5?
White Balance is not a setting that can ever be turned off, it is simply your camera's way of telling what is white so that it can process colors correctly. You can however adjust the white balance manually or simply set it to auto. Auto white balance usually works great and I would highly recommend using it. To adjust your white balance, here are the steps:
1) Press the menu button. scroll using your arrow pad to the WB option and then press the Control Button.
2) This should bring up your white balance selection screen. Keep in mind that if your camera is in full auto ( the dial is set to the camera icon ) you will not be able to adjust your white balance.
I hope this helps!
tip
SERVICE MODE POWER SUPPLY AND INVERTEE CIRCUIT
White balance adjustment
Pre-adjustment
The set should be working for over 30 minutes before white balance adjustment so that it can be in a stable state. Use white balance apparatus CA210 and change to BBY channel to adjust white balance; Only need to adjust chromaticity coordinates when color temperature is 10000K (namely "COOL") for the unit. To meet testing requirements of BBY when color temperature is 8000K or 6500K, make sure chromaticity coordinates of bright scale is X=280 ± 5 Y=288 ± 5, chromaticity coordinates of dark scale is X=280± 8 Y=288± 8; Manual adjustment of both groups of white balance datum YPbPr white balance adjustment.
FOR MORE CHECK
Electronics Equipment Repair Center
How do I get into the service menu of my 32LG30-UD. Not the settings menu that I get by pushing menu, but the actual service menu where i can adjust the balances, and other adjustments?>
My tv looks green&can not be adjusted.it is a sony.serial#kds-r50xbr1
Press Menu, Video Custom Settings, adjust Hue to reduce green tone, if that does not solve your problem, go to Advance Video Settings Menu, White Balance, adjust white balance by tweaking R, G, B gain/ bias settings or hit Initial set for factory default settings.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
