I wonder why your question ended up in the wrong category.
Now that we know that it is a propane heater and not a TV I still don't know the brand name or model. I think you said 5th. wheel.
Most rv furnaces are are very similar. This is a link to trouble shooting a RV furnace. http://www.rvforum.net/miscfiles/Furnace_Trouble-2.pdf
so the problem is air vac switch need to closed before the fan star running is 24vac power them we need to move to ignition control muddle (IID) CHECK f-1 and f-2 for 120vac going to fan , make sure the heater is calling for heat , good look and take you time,
So good news and bad news. Bad news is the remote portion for a 1998 Cadillac Catera Key Fob requires profressional programming. We suggest using a locksmith, they should save you some money compared to the dealer.
The good news is if you need to program another transponder key, you can do that yourself. Get a spare key cut and simply follow the instructions below:
If you need to order a key or remote you can order them online and save even more money: https://www.keylessentryremotefob.com/Cadillac-Catera-Remotes-and-Keys-s/5113.htm
· Switch ignition ON with master key to be programmed
· System LED will illuminate
· After approximately 10 minutes system LED will switch OFF
· Switch ignition OFF
· Wait 5 seconds
· Wait 5 seconds
· After Approximately 10 minutes system LED will switch OFF
· Wait 5 seconds
· Start engine
· New master key now programmed
· Erase stored trouble codes
· Replacement parts caan also be programmed using diagnostic equipment
· NOTE: The vehicle learns the key transponder information on the ignition switch transition from OFF to CRANK. Ignition must be turned OFF before attempting to start the vehicle
· Insert master key into ignition switch
· Remove master key
· Within 10 seconds insert new key
· New key now programmed
· NOTE: A maximum of 10 keys can be programmed using the master key
FIRST ... CHECK YOUR FILTER !! IT MUST BE CLEAN ! THERE IS A PRESSURE SWITCH ON THE HEATER WATER INPUT LINE . IT MAY NEED TO BE REPLACED .. JAY.. THE POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA
Is it Propane or Natural gas? Check your gas supply pressure.Also, open up control panel, accessable by removing the plastic exterior panel with 4 screws, check to make sure no critters got in and chewed wiring.
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
The users manual for these pool heaters is very thorough and address this problem in the flow chart. Try that and see if you get the solution you are looking for. A lot of the questions needed to troubleshoot cant be answered unless you are looking directly at the heater.
