Hayward H-Series... | Posted on Dec 09, 2017 | Be the first to answer
Hayward H-Series... | Posted on Mar 19, 2016 | Be the first to answer
Hayward H-Series... | Answered on Nov 20, 2013
Hayward H-Series... | Posted on Aug 23, 2012 | Be the first to answer
Thank
you for posting your question here on Fixya.com.
First you
will need to get a hold of a digital or analog multimeter and set it for the
lowest range of Ohms you can. Your safety circuit is a string of several switches
all strung together in a row with the gas valve at the end and the beginning of
said string. Any one switch being open or a bad connection anywhere in the
circuit and the heater will not fire.
You task is
to remove one end of the circuit from the valves TH or TT post and put one end
of you meter on that wire and the other end on the TH/PP terminal. It will
likely read infinite resistance. Leave one meter lead where it is and remove
the other. Follow the circuit from the connected lead up to the first switch.
Check continuity from the lead left connected to both sides of the switch. If
there is continuity to both sides the switch is fine. Keep moving from switch
to switch until you find the bad switch or connection. There may be more than
one. When the circuit is working properly and there is nothing within the
heater to cause it to shut off you should have 5 ohms or less across the entire
circuit. Once you get the reading to that level the heater will work as it
should
If you are
not familiar with the process I described you would be better served hiring a
pool technician to perform this repair as you can cause significant damage to
the heater if you do not repair it properly.
If
this answer does not fix your problem, please comment with additional details
prior to rating the answer. Positive feedback is appreciated once your problem
is solved!
John
Hayward H-Series... | Answered on Jun 06, 2011
Hayward H-Series... | Answered on Jul 25, 2010
Hayward H-Series... | Answered on Jul 05, 2010
Hayward H-Series... | Answered on Jun 05, 2010
Hayward H-Series... | Answered on May 20, 2010
Hayward H-Series... | Answered on May 15, 2010
Hayward H-Series... | Answered on Apr 23, 2010
Hayward H-Series... | Answered on Apr 11, 2010
Hayward H-Series... | Answered on Aug 29, 2009
Hayward H-Series... | Answered on Jul 23, 2009
Hayward H-Series... | Answered on Jun 22, 2009
Hayward Pool &... | Answered on Dec 19, 2020
Hayward Pool &... | Answered on Sep 12, 2020
23 questions posted
776 Questions
134 Questions
105 Questions
113 Questions
87 Questions
