Refrigerator is beeping continuosly. Frig / freezer not cooling, nor working. Digital temperature display is blank. Light is on so there is power. Frig only 4 years old. Model FFHS2313LPO. On line owner manual is no help.
The problem is most likely the=> 241739710 Temperature Control Board That is the electronic display that you said is not working. Sometimes there may be signs that the board is defective but most times there is no physical sign the board is defective, I am here should you need me, Thanks John Tripp Appliance 911
Ive got a code 4 on this model and the freezer is working just fine and the fridge is cold to the point were its slushing milk in the door
we need to have a look at the 296451600905 Auto Damper that regulates fresh food section temperatures
241600905
this is not the same post as your first post what happened?
SOURCE: frigidaire refrigerator model FRT21LRGW5-compressor sound is loud
Sounds like the start relay or start capacitor has failed.
Unplug the unit until you can get a replacement or the compressor will be ruined (if it's not already.).
PTC start relay is P/N 218721108 $36.49
Capacitor is P/N 218909901 $7.99
P/N and pricing from Sears Parts.
If the unit is not cooling in either section of the appliance, you are experiencing some form of sealed system issue. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Unless the unit is displaying an error code, often alpha-numeric, then you would need to contact your manufacturer and then a professional to move forward accurately.
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper that's bad.
Here is the part to order.
Y'all REALLY need to read the question. The display is not working and the fridge is dead. It's a bad board. Geesh!
