Frigidaire Professional Series PHS68EJSB Stainless Steel Side by Side Refrigerator Logo
joseph Gunther Posted on Sep 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a side by side frigidaire model PHS68EJSB0 and the display panel that shows the freeser and refrigerator temperature is not working and is not lighting up . also there is a beep every few seco
This unit is only 3 years old. there is a beep every 5 seconds and the temperature display is not lighting up
  • Official Brand Answer 4,342 Answers
  • Posted on Sep 05, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466901
Points
5907
Sounds like a repair tech needs to diagnose the control board for a replacement. Make sure the temperatures inside are not increasing so you don't lose food items.
Appliance Service
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Sep 03, 2013
Appliance Service
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
15406
Points
26
Y'all REALLY need to read the question. The display is not working and the fridge is dead. It's a bad board. Geesh!
5 Related Answers
cautionflag1
David
  • 116 Answers
  • Posted on Jan 30, 2011
SOURCE: Hi, I have Frigidaire side
It is probably a cracked lower bushing or loose lower hinge. If the hinge is tight, then the bushing is probably bad. It is not a hard part to change. Empty the door then then remove the top door hinge. The door should lift off the lower hinge and expose the bushing. Put in a new bushing, grease it a litte with some Vaseline or equivelent and reinstall the door. This link has an exploded view and part # of the bushing (#22 on the diagram). http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150332&diagram_id=1239787#d1239787
Hope this helps
Anonymous
  • 473 Answers
  • Posted on Oct 14, 2007
SOURCE: food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Anonymous
  • 43501 Answers
SOURCE: My Frigidaire side by side is not getting cold
If both sides are not getting cold then you probably have a problem with the refrigeration unit of some kind...
It could be as simple as cleaning the condenser coils or it could be much more complicated like a leak in the refrigeration system...
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Anonymous
  • 43501 Answers
  • Posted on May 06, 2011
SOURCE: My fridgidaire side by side
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Anonymous
  • 43501 Answers
  • Posted on Jun 03, 2011
SOURCE: The Frigidaire Galaxy Series Model GLHS37EHSB6 is
heatman101
How to change frigidaire phsc239dsb5 refrigerator change from celsius to fahrenheit
The steps to change the temperature display from Celsius to Fahrenheit on a Frigidaire PHSC239DSB5 refrigerator may vary depending on the specific model, but generally, it can be done through the control panel. Here are some steps you can follow:
  1. Locate the temperature display on the control panel of the refrigerator.
  2. Press and hold the "Option" button until the display starts flashing.
  3. Use the "Option" button to toggle through the display options until you reach the temperature display setting.
  4. Use the "+" or "-" button to switch from Celsius to Fahrenheit.
  5. Once you've made the desired change, press the "Option" button again to save and exit.
Note: The specific instructions may vary depending on the model, so you may want to consult the user manual or the manufacturer's website for more detailed instructions.
2helpful
2answers
I have a side by side Frigidaire fridge that has a blinking H on the temp display and it is blinking. What might be causing this?
It is a warning that the fridge thinks the defrost heater is bad
Frigidaire side by side Model Ffhs2622msu Flashing H on the... H means that the refrigerator thinks the heater is bad. You'll need to pull everything out of the freezer and remove the back panel inside the freezer. You'll see the silver evaporator coils with the evaporator fan above it.
Apr. 14, 2020
What does flashing h mean on Frigidaire refrigerator?
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls Ā·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open Ā·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
Ā·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset Ā·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Flap won't stop humming buzzing
The control on the bottom freeser not working properly, the display number for the freezer is showing a temperature of 50 degee, where was at -4, now it is not freeze.
might need a new temp switch of you lost your freon wich will no longer cool like a ac in a car call a plumeing and heating guy to check ac level in the comprassor good luck
1helpful
Frigidaire refrigerator model ffhs2313lpo
The problem is most likely the=> 241739710 Temperature Control Board That is the electronic display that you said is not working. Sometimes there may be signs that the board is defective but most times there is no physical sign the board is defective, I am here should you need me, Thanks John Tripp Appliance 911
4helpful
Temp display (fresh food temp) has flashing # 4. Any idea's? Mod# GLHS36EFSB1 - side by side fridge
my Frigidaire showed the number 4 on the display after power outrage. And the temp is really warm inside. I unplug the power and plug it back 1 minute after. now I can set the temperature and it's working fine.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
