Susan Arp Posted on Apr 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to connect samsung tv and dvd to 6000rx? - JVC Audio Players & Recorders
Rudy Rutenber
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 79 Answers
  • Posted on Apr 24, 2014
Rudy Rutenber
Expert
Level 2:
Cheetah:
Answers
79
Questions
Helped
18899
Points
133
I'm not familiar with this model. One thing for sure is the output from the audio and video on the TV has to go to an unused input of the receiver/amp. You can download a user manual from JVC if you don't have one. The first few pages usually give connection examples.
2helpful
2answers
I would like to play DVD onto my Samsung tv screen
Surely there is no reason why you shouldn't.
All that should be needed is a connection from the DVD player or computer to the TV set with a suitable connecting lead.
2answers
No Signal form Samsung DVD R 155 to Vizio TV
tried to hooked up to other tv or other component input with in the tv and replacing cable wire just to ensure where the main cause of the problem.
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
3helpful
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
2helpful
Connecting samsung dvd to Philips 47PFL6704D LCD TV
Hook up your cables from your DVD player to these input on the back of your TV. 6131e0b.jpg The group of ports should be labeled as video 1 input. Use the Yellow, Red and White on the back of both DVD Player and TV. Then, change the input on the TV remote to input or video 1 to watch the DVD Player.
1helpful
Nosignal when i power it on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are trying to view the DVD on the Samsung TV, you need to firstly connect the DVD to the appropriate connection on the TV.
Once connected, with a Samsung TV, you need to press the SOURCE button on the TV remote control to view any external sources such as your DVD player.
The ‘NO SIGNAL’ message would indicate there is no signal, if you have not tuned your channels in, this may be the digital tuner you are viewing. Press the source button whilst a DVD is playing in the DVD and see if an image displays.
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Dvd recorder does not have tv tuner
sure you can record from your TV. You need to connect the AV1 of the tv to the AV1 of the DVD recorder. Then, when the TV is running, you can simultaneously record on your DVD recorder.
Use a SCART cable for the connection.
Connecting my DVD player to my widescreen TV
PRETTY SIMPLE, CONNECT YOUR 3 PRONG CABLE FROM VIDEO AND AUDIO OUTPUT ON THE COLBY DVD TO THE INPUT VIDEO/AUDIO ON THE TV.SWITCH AV INPUT ON THE TV TO VIDEO 1.
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
