Samsung DVD-V9800 DVD Player/VCR Logo
Question about Samsung DVD-V9800 DVD Player/VCR
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be connecting the DVD player to the TV?
Posted by clarkemorinw on
Paul
    Sergeant:
  • 381 Answers
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Posted on Dec 30, 2009
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
My dad just purchased a 2004 memorex t.v. with built in dvd and vhs players. He wants to know if he could record a vhs to a dvd on t.v.
No,the DVD player build in tv can't record,only play DVD Disc only.Want to record personal VHS tapes only to DVD Discs,must have a seperate device unit VCR/DVD RECORDER device player not a device unit VCR/DVD PLAYER.Connected to the tv record VHS tapes to DVD Discs.
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
2answers
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
2answers
I can play DVD's but not VHS tapes. I hav checked all connections and several tapes to no avail. Thank you ! Ol' Fred
Hey Ol' Fred...
One of my good friends is an ol Fred so I felt compelled to stop in and help!
I'm not sure of your setup, but if you've got a combo DVD/VHS unit, make sure that you have out puts to the TV for Both parts separately... You can designate by accessing the TV's onscreen menu and setting up a separate source for DVD and one for VHS. I've found on my projection TV that it's best to use the Coax cable connections for the VHS to TV.
Then once it's setup with separate hookups to the Tv, you should have audio and video for VHS...
k
2answers
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Vhs playback problem
either extremely dirty heads or there is a tv/vcr button that needs to be toggled. Most have auto tracking, old ones have a knob or 2 buttons under a panel somewhere for tracking.
2answers
VHS tapes are black and white
The tapes are B/W or one of the playback video heads is not making contact with the tape. The video head may need to be adjusted. You can take it in to get it fixed or buy a new one. The unit today is worth around $25-$30.
Watching videos on a computer
Yes. DVDs are easy as you probably already know, you just need a DVD capable drive and appropreate software to play. VHS tapes are another matter altogether. You'll have to purchase something that will convert the analog signal from the VHS player to a digital signal your PC can use. I have a device I use to convert VHS tapes to DVD (ADS technologies) I could use to watch tapes but the software leaves a lot to be desred.
Marvin
Marvin
