NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
Ed Kirkpatrick Posted on Apr 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to connect my cell phone to my wireless router
Mike M
Level 3:
  • NetGear Master 3,349 Answers
  • Posted on Apr 04, 2014
 Mike M
NetGear Master
Level 3:
Answers
3349
Questions
0
Helped
686889
Points
16707
There is little point in posting a question with no real information.
Saying something is "broke", "doesn't work", "can't connect" or that you "need" or "want something" is pointless without ALL the information.
What actual products are you using? Makes, models, connections...everything about your problem is necessary. We are not there with you. We cannot see what is obvious to you. Most problems occur when you try to get something to work with something else. We need to know all the things you are using and doing that ends with your issue.
The issue is the last thing we need not the only thing.
Hp laserjet wireless not found on my phone
why not RTM? (omg)
read the manual,
all this is covered there. how to CONNECT.
there is no phone support, apple or android. only xp to w10.
on newer printer, far newer, the phone can be linked to HP smart print servers and to your home system printers.
https://support.hp.com/us-en/product/hp-laserjet-pro-cp1025-color-printer-series/4052955/model/4052971/manuals
here is HP site page showing how to do that,
http://www8.hp.com/us/en/ads/mobility/overview.html
first pick a printer that does that.
using the smart app
or ePrint.
there are many ways to set that up, but direct cell to printer.
no. (yes new products can do direct cell print)
that is called wireless direct print , features, as see here.
http://www8.hp.com/us/en/ads/mobility/wireless-direct-printing.html
you said you have phone (cell apple or android?_)
then said have a laptop.
my cell , is android and I use local wifi , to save 3g charges
do you?
my laptop has internet connections 2 ways, wired, and wireless
does yours have wireless. seems not.? but.... do you?
you said no router, but if you go to any ISP today
and he installs internet service, there are 2 hidden router now
inside the old name modem,
the modern cheaper modem has that, hidden is side.
has 3 things in the black box.
so what do you have there that we cant see, devices to the ISP
with names and model numbers.
knowing that tells the helper what is possible , (all things)
my guess is you want to print, using the CELL.
if you dont have eprint mail the docs or photos to the laptop
then, print from Laptop
to printer using a USB cable, (USB is 10x more easy to make work)
your printer can connect up 3 ways.
Printer USB to PC. direct wired printing. ( always a choice, direct)
Ethernet to router. wired. (all things connected to this router can print.
wireless to router. printer to router joined, and print from any thing at home connected to said router.
if it must be wireless, (you must have that?)
then buy a router. and use that, and is safer behind any router firewall vastly saver too boot.
1helpful
Lose nettalk connection from router after on phone for twenty minutes
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Can we connect n8 to any wireless router
if n8 can connect internet without wireless router than you can connect it if not dont buy
Blackberry 9300 koodo WEP codes
To connect to your wireless router you need the wireless router's WEP or WPA or WPA2 encryption code.
To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
I want to connect my Samsung Corby GT B3410 to laptop so that i can acess net??
Any phone,tablet or wireless end device can connect to a wireless router given that the devices have wireless features. You also must have active wireless internet connection. As long as the wireless settings on the router is ok,that means that anytime you want to connect wirelessly you shouldve access doing so. If you want to connect your mobile phone for the internet via network cable,theres no way you can do it. Wirelessly is the only way for you to got internet connection via router.
1helpful
I cant get my cell phone to connect to the router i have a motorola flipside. it says router not found, the laptops here connect but my phone wont
you will have to allow the device in router wireless list it will not connect if it is not listed in the router list.
to do this you will have to get in to the router set up page and list the phone.
HOW DO I CONNECT TO MOTOROLA SB5101 MODEM AND KEEP MY INTERNET CONNECTION
1. if this is wireless connection then you will have to possibly move the router at least 10 to 20 feet away from any other wireless device or television, cell phone,cordless phone or TV antenna or digital TV box.
Also florescent light will affect the signal from a wireless connection.
Cant connect with the modem after cell phone mishap
Reconfigure your computer's software that was changed to make the phone work.
On the router, rtfm.
I doubt a cell phone could change the router's settings.
1helpful
3answers
Zyxel will not connect to my laptop wirelessly
Step 1 - If your laptop contains an ethernet port for a wired connection -- connect it to the router using a wire. Try to use the internet -- if it works we are assured the router to the internet is correct.
Question 1 - Please respond to this with the make and model of your laptop and if you have one the make and model of wireless adapter for use with the computer.
Question 2 - Was this router originally purchased new or used?
Question 3 - Has this router work wirirelessly with any other computer you know about?
Question 4 - Have you configured this router since you got it?
Question 5 - Have you had someone else configure this router since you got it?
2answers
Can't connect
First if your computer has an ethernet port attempt to connect through the router to the internet with a wire. If that works the next question is did you buy this device new or used? If used we can work to assure we know the configuration of the device. Second what is the manufacturer and model of your computer? Third, if the wireless adapter is not built into the computer what do you know about the make and model of the wireless adapter? Armed with the above information we should be able to resolve the issue.
Thanks
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
