Question about netTALK DUO Wi-Fi VOIP Internet Phone Device With 12 Months Service
Lose nettalk connection from router after on phone for twenty minutes
Talking on nettalk is fine for twenty minutes then lose connection . tied into router
  • netTALK Master
  • 32,281 Answers
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Jan 28, 2013
6ya staff
SOURCE:
Skype calls break after every 2 mins when talking on tablet
it could be a connection in between wireless router and your tablet.
if your tablet having ethernet port connection pls try with this port and make sure the fault in wireless connectivity. if yes pls try with change wireless sequrity and test again
Apr 08, 2013 | Computers & Internet
My nettalk duo's red light is constantly on .its not working. how can i fix it.
ANSWER : I have had the solid red light come on every so often. I would power cycle the nettalk and it would be find for a while, then go out again. The solution is to assign the nettalk device a STATIC IP that is outside of the range of ip addresses assigned by your router for DHCP.
Example, my linksys e1200 router by default assigns DHCP addresses starting at 192.168.1.100 and goes to 192.168.1.149. If you assign the mac address of the nettalk to an ip outside that range (that is not 192.168.1.1 because that is your router) like 192.168.1.20 it will solve this issue. whenever the nettalk connects to the router, it will always get 192.168.1.20, I think the nettalk can't handle getting different ip addresses from the DHCP server.
Then tTurn off the nettalk, then do a power cycle on your router.
Feb 11, 2012 | NetGear Computers & Internet
I just setup Nettalk Duo and can send and receive calls. But the Answering machine will not work. I have it set for 4 rings and Nettalk voicemail is set for 5 rings. Any suggestions, please help.
Login to your Nettalk account and click on the voicemail tab on the left. Make sure to turn off your voicemail settings for your Nettalk device and save settings. Your answering machine should now pick up after 4 rings.
Mar 11, 2011 | Uniden DECT 6.0 Cordless Phone ID
Have an SBG6580 and purchased a NETTALK DUO (VOIP). Which is trying to connect but can't. Tech support at Nettalk tried to change some settings but it looks like modem is still blocking the port. ...
The only way I got the NETTALK DUO to work keeping my SBG6580 is to use it in cascading mode with my old Linksys router. When I plugged the DUO into the Linksys it worked great.
Nov 14, 2010 | Motorola Computers & Internet
I have a nettalk phone. The "techie" at nettalk says I should reset the router for the phone to work. How do I reset the router?
There has to be a small hole (usually at the back of the router). Inside this hole is a button. Use a paper clip to push this button for about 10 seconds fro the router to reset.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 19, 2010 | Dynex DX-E402 Router
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
www.belkin.com/support
Regards,
Aysaam
Apr 13, 2010 | Belkin N1 Vision Router
My belking keeps losing connection during games?
If your wireless you probably need to change broadcast channels on the router ( to the last channel) if its hard wired, you probably need to port forward the ip address for the Xbox
Oct 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Lose internet connection
Try Unplugging Your Router And Modem For 1 Minute. Then Re Plugging The Power Cords In.
Jun 14, 2009 | Dynex DX-E401 Router
Runs about thirty miles then acts like flooded or exhaust plugged
try checking your cadlist convert on your exhusted
Dec 26, 2008 | 1996 Dodge Caravan
Router loses connection
Somebody else on this site had similair troubles and it was down to the fact that the cable company change the IP address of the connection frequently. Now, if this is the case your router will lose connection if it's a seperate modem as it will lose the modem IP address. I would contact your provider for a solution if this is the case.
Jan 11, 2007 | NetGear WGT624 Wireless Router
netTALK DUO Wi-Fi VOIP Internet Phone Device With 12 Months Service Logo
226 people viewed this question
Top netTALK Cell Phones Experts
Ekse
Marvin
Marvin
William Alequin
Are you a netTALK Cell Phone Expert? Answer questions, earn points and help others
