Sharp XL-MP60 Shelf System Logo
A
Anonymous Posted on Mar 16, 2014
Keeps showing error when turn on - Sharp XL-MP60 Shelf System
1helpful
Hp 6180 all in 1, the screen shows 83c00020. It keep shuttung off in a loop .please help
The error code 83c00020 appears when the printhead of the system fails. Fix the error by resetting it and changing the printhead of the printer. Follow the steps below to fix it.
Step 1: Turn on the printer and remove the power cord from it.
Step 2: Leave the printer for 60 seconds.
Step 3: Connect the power cord back to the printer.
Step 4: The printer should turn on automatic
Step 5: If the printer does not turn on automatically, then do it manually.
Step 6: Open the cartridge access door.
Step 7: Remove the printhead out of it and keep it aside for recycling.
Step 8: Buy the original printhead accessory from the HP website.
Step 9: Replace the printhead and close the cartridge access door.
Step 10: Following the above steps should have fixed the error.
For Support Call Our Toll-Free 1-866-293-9220
How do i fix error code C-3502 on a konica minolta bizhub500 photocopier
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier.
My kodak dx6490 keeps showing error l-02
Hello Lester, These Kodaks use codes for diagnostic reasons, they will show a code when there is a reason for service. They are used by the tech for diagnostics just like your vehicles fault codes.
Best Regards, Russell
Printer is showing error 6A80. I turned it off and on and it still shows the same error. What is the error and how do I fix it?
Hi
You need to replace motherboard of your printer
You better replace it with a new printer
Pls vote us to keep us alive
My kenmore elite microwave when turned on shows a f7 error code.
f7 keeps showing up and the microwave keeps cutting off,f7 code shows up. what do i do
I keep getting a 50.2 fuser error. Turned off
wheb i give the print out, just show error 50.2 fuser error,
pls give me solution what may problems
2helpful
1helpful
It keeps saying file error
Check the format of the music you are playing and if you have music that requires the license it will load the music but not play. It will show up as a file error.
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
