Sharp MD-MS702 Personal MiniDisc Player Logo
A
Anonymous Posted on Sep 05, 2011
'TOC error a' on sharp minidisc player 701. Has not been played for some time discs all 12 of them, give the above error. Can you help??!!
Pennywhistler
Level 2:
Champion:
New Friend:
  • Expert 231 Answers
  • Posted on Apr 16, 2014
Pennywhistler
Expert
Level 2:
Champion:
New Friend:
Answers
231
Questions
0
Helped
72386
Points
282
Users manual http://www.minidisc.org/part_Sharp_MD-MS701+MS702.html
1 Related Answer
otacon
Damen Wong
  • 1950 Answers
  • Posted on Mar 17, 2008
SOURCE: sharp minidisc MD-MT20 H - TOC ERROR a
I am sorry to say but your unit needs to be sent for repair. The TOC error shows up when the unit can't read the Table Of Contents of the disc (and simply shuts down after trying)....and in your case, you said it can't read any disc. This indicates that the lens unit has malfunctioned and needs to be repaired or replaced.
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
When I try to play my sharp MD-MT15 midi dish player, it did not play. It say TOC ERRORa. Please some one help me to fix it. Thank you very much!!!
That's an ancient player!
Try using a different disc. Try using the external power supply.
User manual http://www.minidisc.org/part_Sharp_MD-MT15+MT16+MT20.html
2answers
My MD-MS702 gave me very good service. Unfortunately it was not used for five to six years and now when i switch it on after full battery charging I get TOC error on all of my recorded discs. SOS, as I am...
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
2answers
When I input a disc and hit play I receive an error which says "TOC ERRORa".
Possible that the disc is not reading and so the the TOC- table of content error must be referred.
It can be due to a poor head tracking or the failure of the data being read or processed.
Clean the head and use a good disc to be checked once again. If so the optical head can be faulty as it might be getting weaker.
1helpful
Ive just got a mini disk player and its comeing up toc error,can you help me please
Probably not. There are various reasons that TOC errors occur, some are fixable and others not, but Sharp MD units were really known to suffer from them for multiple reasons all at once. TOC means Table Of Contents; it's an index file on the disc which tells the host machine where everything on the disc is located and the TOC is modified whenever you edit a disc. Sometimes the file gets corrupted, but often the machine itself simply becomes unable to read the disc and as the TOC is the first thing it tries to read then you get a TOC error.
If you're lucky the TOC error is limited to a single minidisc; if this is the case then it's just one faulty disc and although there are ways to perform TOC cloning they usually involve hacking the host machine in various ways which may cause permanent damage. Unless the disc is important, just chuck it away and use a new one. If the fault is with the player then again, just chuck it into the nearest electronic waste recycling bin. Spares are not available, and as it's a Sharp, diagnosis will be difficult and the fault likely to return.
Many MD players are practically worthless these days so they're often available on FreeCycle and Freegle groups: Sony are the preferred choice by far, and are also the most commonly offered brand, but take whatever is on offer without complaint and worry about problems later; after all, they are free.
4helpful
2answers
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
8helpful
Sharp minidisc MD-MT20 H - TOC ERROR a
Toc error problem
HEY,
t is not the topic, but I'm for al long time searching for the sharp md-mt20h and I see that you buy a new md player? Were can I buy him?? thanx
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
