Sharp XL-MP130 CD Shelf System Logo
Posted on Aug 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timer light blinks ....- (four shorts and a long). Unit unresponsive to all buttons. Resetting doesn't help. Condition resulted from a sequence of 4 (four) 1-second house power interruptions/restarts while unit was in standby (as off as it gets without unplugging). All 5 fuses on power supply board appear OK.
  • hwinsor Aug 14, 2009
    The unit has been unplugged for a month, but starts with the blinking red light as soon as plugged in. I have tried all the manual suggestions. The reset procedure does not work: I assume that means that the system is either not in "standby" (but it cannot be switched into any other mode), or that somehow the power surges did sometning. Sharp wouldn't tell me what the pulse code means, and a local Sharp store told me that it would cost me 2-3 days and $20 plus two trips to their store to have them look at it. The screen never lights up, and only the ". . . . _" (four short timer pulses, followed by a long pulse) can be seen. The power supply puts out 6 and 12 volts.
    If you have access to the repair/servicing manual, or web access like the store to the pulse code list, I'd know what to do with the unit.
    A new solution has been posted for your Sharp XL-MP130 CD Shelf System Problem on FixYa.com.
    Click here to read the solution:
    http://www.fixya.com/ThreadView.aspx?thi...
    Regards,
    The FixYa Team
    This fix doesn't work! HVWinsor Sharp has a list of blink codes, but they won't tell me what 4 shorts followed by a long means.
    Visit your Profile to see all of your Problems and Solutions:
    http://www.fixya.com/users/hwinsor
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Aug 14, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1186310
Points
12747
First, try unplugging the unit for a couple of hours. That should reset the internal microprocessor. If that fails, try pushing all of the buttons one at a time. If one of them is stuck, nothing will work properly. You should be able to feel the button working.
There is also a reference in troubleshooting in the manual between page 37-39 which i assume you have already consulted. It does recommend turning off and unplugging for up to 5 hours and then reconnecting and using the button sequence to clear memory.
  • 1 more comment
  • Anonymous Aug 14, 2009
    I am trying to contact SHARP SERVICE Center currently to see if I can get someone to provide me witrh this code. if you respond to this posting i can reconnect to you.for another 30 mins
    OK here it is right from Sharp's service center support.
    The unit is reporting power surge and if the usual unpluging does not fix it then there is damage to the power unit. I mentioned that alll fuses were OK but they still say that the fuses being intact does not eliminate the supply from damage
    The flashing lights are operating from the low voltage part of the power supply but the main transformer is what is damaged. The buttons are operated from this transformer and as they do not respond then this is the area of damage to the supply.The unit will have to be taken to a service center.
    If you are in Australia check a service centre near you from here
    http://support.sharp.net.au/default.asp?...
    if this is helpful to you pleae tick the ratings box to show that you are satisfied with our efforts in helping you solve the problem
    well as i said 4 shorts 1 long is report of a power surge
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
1helpful
2answers
No power on (LCD27TV006HD)
Does the standby light continue to blink? IF so, count the number of blinks and go to:
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
That may help you decide what is going on.
In the long run you will probably need to have a tech take a look at it. The problem you describe is usually a serious matter that needs repair by a trained technician..
Goodluck,
Don't forget to rate me as fixya...
1helpful
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
Overhead light will not come on when door is opened
Press and hold the Lock button until the light blinks (about 10 seconds). A single blink indicates that the timer is reset to 1 1/2 minutes. Repeat the procedure and the light will blink twice, resetting the time to 2 1/2 minutes. Repeat again for a 3 1/2 minute interval, etc. up to a maximum of four blinks and 4 1/2 minutes.
1helpful
When our garage door opens, my light turns off immediately. How do I get it to stay on for about 5 minutes?
Try this:
4helpful
The light stays on for a long time although it shuts off (a lot more that 4.5 minutes). Can this be adjusted to be shortened? Where and how on the unit?
If you have one of the newer models the duration can be changed by holding in the lock button until the light blinks (about 10 seconds.) A single blink indicates that the timer is reset to 1½ minutes. Repeat the procedure and the light will blink twice, resetting the timer to 2½ minutes. Repeat again for a 3½ minute interval, etc. up to a maximum of four blinks and 4½ minutes.
If your opener has the motion sensor feature and a person enters the garage and walks in front of the door control the light will come on for 5 minutes and then shut off.
Unresponsive buttons
First, try unplugging the unit for a couple of hours. That should reset the internal microprocessor. If that fails, try pushing all of the buttons one at a time. If one of them is stuck, nothing will work properly. You should be able to feel the button working. Report back here with your results.
Dan
Mitsubishi VS-50607
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
