Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
A
Anonymous Posted on Mar 13, 2014
Error E:01 the drum will not spin
MasterTech
Level 2:
Sergeant:
  • Bosch Expert 96 Answers
  • Posted on Nov 15, 2015
MasterTech
Bosch Expert
Level 2:
Sergeant:
Answers
96
Questions
0
Helped
88925
Points
521
The control board is seeing the door as open even though it may be closed. Here is how to repair it:
http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-code-er%3a01/1
1helpful
Bosch Washer WFK2401UC/01 Does not spin. Replaced Power cir. Bd. Turned on started right up. completed cycle. Went to wash this morning Drum will not spin
Sometimes the brushes on the motor get worn and they cause motor to act intermittently. I changed my brushes and this corrected the problem of not washing or spinning.
My ricoh printer stoped printing and came up with an error code sc440-01
Possible Drum motor, or sensor - you would do best getting a professional in to repair, as self repair on these will no doubt end in issues..
Error code l 4 01
L4-01 is a main motor lock error. More than likely something is locked up, rather than a problem with the motoer itself. Make sure the drum and Developing unit are turning freely. The Fusing unit binding can also cause this error. Turn the machine off, remove the developing unit and the drum. Put the developing unit back into the machine, close the doors and turn it on. If you can hear the motor run and there is no error code, then the drum is locked up, probably due to a flipped cleaning blade. The next area to check is the developing unit itself. Sometimes if the bushings go bad at the ends of the developer roller, it will cause a motor lock. There is a white coupling on the rear side of the developer unit. Turn it counter clockwise about a half turn, being careful to hold the unit level. There should be little resistance. If all seems O.K., then the Fusing unit is probably the cause. Also pull out the paper cassette and make sure nothing is preventing the pick up rollers from turning.
9helpful
3answers
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
1helpful
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
2helpful
Hi there, have got a bosch 1200 classixx WF02466GB/01 - pumps working but will not spin the drum. Belt is ok and drum does move when you push it.
To make sure it is not due to water left in the drum, remove the filter, and clean.
If it still does not spin, then it is more than likely that the brushes need replacing in the motor..
You will have to remove the motor to check them..
If they are less than 3 or 4 mm long, then they need changing.
Hope this helps.
1helpful
Ue error during spin mode (b4 spin up happens) empty. wm3677hw
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. Also you have mentioned that the drum with full load has no such problem. It means that the drum cannot manage its weight in that position. So the problem might b adjustable easily. Try to remove the top panel and check for any slight movement in the position of the drum. Leaving it continue this way might increase the probability for the error to be repeated with the load. Will add some links related to internal diagrams of this model when i find some that might help you to check the drum inside.
Good luck with the machine.Please do rate my solution and post comments and results.
Sunny.
9helpful
2answers
2helpful
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
2helpful
ERROR L4-01
What you have is a main motor lock. Check to see if you have anything blocking the movement of the drum, it could be anything from a staple, a jammed sheet of paper, or a broken drum separation pawl. If you have already removed something from the drum area do a SIMM 14-01 to clear the code.
There also could be trouble with the main motor itself. Check the motor by using SIMM 6-1 to see if the motor turns. If not, check the harness connection between the main motor and the PCU PWB. You may need to replace the main motor, the harness or the PCU PWB.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
