I found the hose hooked to the pressure was clogged down at the tub end. So it couldn't send a signal to the switch telling it the water had pumped out and it was time to spin out, the plugged hose was holding pressure telling the washer (falsely) that the tub had water in it so it won't spin if it thinks water is still in the tub. By pulling the hose off the switch end and blowing thru it to clear the lint and soap slime that was plugging the other end it works perfect now.
Hello Everyone,
I had a similar problem with my WLSR2000G2WW washer. The pump kept running but no spinning at all. This post helped me get the washer spinning again, Thank You!!
I removed both hoses to the pump (inlet and outlet), and used a hose to flush them out. I even removed the hose exiting the washer and flushed it too. I'm not sure which hose was responsible for my blockage, the hose exiting the washer did look a little twisted/kinked so I made sure I straightened that out.
Anyway I'm back spinning again.
Best Wishes!
Rick
