You can't erase a CD/DVD+R as they are write once - CD/DVD + RW can be erased
DVD formatsShort for Short for DVD-Recordable, a recordable DVD format similar to CD-R. A DVD-R can only record data once and then the data becomes permanent on the disc hope it helps
The DVD has burned incorrectly and the data has likely corrupted somewhat to the point where the DVD player/writer can't read it. You may be able to watch it on your computer with a DVD drive.
Try saving it to your computer, then erasing the disc and trying to record something short to it and play it back - if it plays back, it's likely to have been a recording problem, however, if you get the same problem, it may be a dodgy disc, a faulty DVD player/writer, or a format problem.
Try this, in order left to right.
Copy DVD to PC -> Erase DVD -> Record on DVD from TV -> Play back
If plays back
Erase DVD -> Continue as normal
If not
Buy DVD-RW (emphasis on the minus) -> Try using that
If that works continue as normal, otherwise...
Return the DVD player/writer under warranty for repair/replacement.
If you are using a DVD-RW or DVD+RW, you can format the disc by performing "Format". You can format DVD-RW for either video mode recording or VR mode recording. DVD+RW can be format in order to erase all content of the disc.
You may not be able to reformat a disc that is not previously formatted by your recorder an example would be a. DVD disc formatted by PC or another recorder.
Follow these steps to re-write:
Insert a recordable disc.
1 Press [SETUP].
2 Select "DVD Menu",
then press [ENTER].
3 Then select "Format", and
press [ENTER].
4 select "Start", then
press [ENTER].
5 Confirm by selecting "Yes", then press
[ENTER].
Formatting will start.
6 Formatting is completed.
When the disc is ready for you to rewrite to "100%" is indicated.
Formatting 100%
HDMI refers to High Definition Multiple Interface. I is a cord made to carry both High Def audio as well as video. Erasing the dvd can be done by a computer software, typically Nero, but I would suggest contacting Customer service to find out if the recorder is capabale of erasing RW media.
HI WE HAD A SIMILAR PROBLEM. THE SOLUTION WAS CLEANING THE DISC. IT APPEARS JUST TINY FLECKS OF DUST AND GREASY FINGER PRINTS CAN CAUSE HAVOC! GOOD LUCK
