20 Most Recent Lite On LITEON 16X DVD BLACK OEM (Come With Software) (D11663VM) DVD Drive Questions & Answers
2answers
How to restore Lite-On DVD
Hi there! Please run the following Microsoft tool in your computer.
http://go.microsoft.com/?linkid=9740811
More info:
http://support.microsoft.com/kb/982116
I hope it helps.
1/16/2013 5:00:10 PM • Lite On LITEON... • Answered on Jan 16, 2013
External dvd player wont play
Use dvd player to another laptop or pc.
If you need more information, reply me soon.
Thanks
9/27/2011 7:27:54 PM • Lite On LITEON... • Answered on Sep 27, 2011
Just purchased a liteon dvd burner.When I try to
you might need a program like AnyDvd which removes copywright from a dvd and allows you to burn it without any restrictions to be able to play the dvd in australia
hope this helps
12/13/2010 8:18:25 PM • Lite On LITEON... • Answered on Dec 13, 2010
Playback has choppy audio
The audio cable from motherboard to your DVD drive got definitely damaged, change it. If problem exists change the lens of your DVD drive, also install up-to-date driver for your audio device.
12/31/2009 4:15:21 PM • Lite On LITEON... • Answered on Dec 31, 2009
My DVD-ROM won't recognize DVD movies
do it only if u r a professional..
open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!!
open up ur system cabinet and see if all the data cables n jumper settings at the back of the drives (master/slave selection)..itz most important..!!
however, at the bootup (0.29sec) start pressing briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del as applicable)..glance in the standard settings if r detected individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) : Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
also try checking itz data cable for loose or faulty..
above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
contact ur system admin/vendor....
11/16/2009 8:07:59 AM • Lite On LITEON... • Answered on Nov 16, 2009
Dvd recorder will not erase
how many times have you eresed the disc?
6/13/2009 1:23:26 PM • Lite On LITEON... • Answered on Jun 13, 2009
Lost recording software kit
If you lost the software, you can try contacting LiteOn for a replacement, but you'll probably have to go to your local tech store and buy more software. I recommend Nero or Easy CD/DVD Creator, or get the opinion of someone that works there. Make sure you do NOT open it until you get home and check online that it has the features you need, as you will be unable to return it if you open it.
11/10/2007 1:08:28 AM • Lite On LITEON... • Answered on Nov 10, 2007
P4B533 doesn't load up windows. reset BIOS,swap memory. Green lite on MB, CPU fan runs. long beep
1. check for keyboard stuck keys. 2. Clean memory and Memory slot well and fix back memory. 3. check capacitors close to the memory slot if they are not damaged, if damaged replace the capacitor with a new capacitor.
8/13/2022 2:07:04 PM • Lite On... • Answered on Aug 13, 2022
2answers
Driver missing for lite-combo sohc-4836k
please will you till me vinaly AC97 ADIO CODE 10 IS NOT INSTALL HOW CAN I UPDATE THIS DRIVE
5/15/2022 1:06:51 PM • Lite On... • Answered on May 15, 2022
I want to move old HDD drive from broken down LiteOn 5045A DVD recorder to replacement DVD recorder machine...
cart before horse.!WELL BAD NEWS (TOPIC) HDD.the drive is 21 years old tech. 2001it is not any kind of modern standard HDDit is PATA(IDE) NOT MODERN SATA (SERIAL ATA)SO ONLY RELIC OLD DRIVES CAN WORK HERE.or run old 20+ hdd tests that take a week to finish(now you see why SATA was born, PATA stinks)and worst is the DVD burner is not a desktop or laptop standard drive and worse yet PATA againthe old DVD drive, replacement can be hard.lite-on does not support old things, gee most makers do not after 17 year old.also read here, and see how spare parts actually workin this old burner systemhttps://forum.videohelp.com/threads/325208-Liteon-LVW-5045-replace-DVD-drive-project-startedwhat your are attempting is not easythe huge problem is fireware in the devicemany not allow larger HDD over 160GB new.or may not allow all makers of the drive to work at all.is not that DVD DRIVE, PATA DRIVE, NOW 100% OBSOLETETHE SAME FIRMWARE RESTRICTIONS (NOT DOCUMENTED ON EARTH i MIGHT ADD) WILL NOT ALLOW SOME DVD DRIVES BY OTHER MAKES.... LOOKING NOW AT OTHER WORKING ON THIS OLD BEAST WHAT DO I SEE IN their nice PHOTOSL (tech eyes win)the hdd iS NOT SATA IT IS 20 YEAR OLD PATA(IDE) JUNK.FINDING GOOD USED PATA DRIVES IS HARD..NEW ONES ARE SOLD AT SCAPLERS PRICES, (AS expected)the DVD drive is clearly custom made by SONy for Liteon..HERE IS DVD PROOF OF NON STANDARD DRIVE(FIT)45ad81af-aef0-4368-8bdf-55959c725f31.jpg
5/15/2022 11:40:43 AM • Lite On... • Answered on May 15, 2022
I have a zipspin c120 pro, the Lite-on ihap 122 drive is bad, will a ihap 124 by lite on work in its place?
Yes. DVD drives are intercompatable for the most part.these days. just pull out the old one, install the new one, and the OS will install the drivers and it will work just fine.
7/11/2019 7:19:29 PM • Lite On... • Answered on Jul 11, 2019
5answers
Can I Install GDMSS Lite on Windows 10 Laptop?
In case you have a good PC, you can easily install it using Bluestacks. Here are the steps:
  1. Download Bluestacks
  2. Search for "GDMSS Lite"
  3. Proceed with installation.
Source: Download gDMSS Lite for PC on Windows 7 8 or 10 10Downloads com
10/2/2018 4:34:20 PM • Lite On... • Answered on Oct 02, 2018
0answers
No sound comeing out next to volume control yellow lite on says overloaded
Rule number 1 in pc troubleshooting and electronic troubleshooting is to always power down the device and turn it back on to see if that doesn't help, if the problem persists. . . you can call us on your fixya app and we can help you fix your issue with no problem. Hope this helps ?? If you need further help, I’m available over the phone at https://www.6ya.com/expert/brant_4c68df22dda524c2
9/21/2017 12:22:55 AM • Lite On... • Answered on Sep 21, 2017
HI I HAVE SEVERAL
Most power supplies have a fuse in them. That is most likely the problem. Otherwise, if you open them up, you can see which capacitor has gone bad, 'cause they will have obviously ruptured.
4/12/2016 11:46:17 PM • Lite On... • Answered on Apr 12, 2016
3answers
Can't import video into Windows Movie Maker
Windows Movie Maker is a basic video editing and creating software developed by Microsoft. It contains features such as effects, transitions, titles/credits, audio track, timeline narration, and Auto Movie. The accepted formats for import by Windows Movie Maker are WMV, .AVI, MPG, .ASF, .WMA, .WAV, and MP3.
Puzzled about how to import DVD to Windows Movie Maker for further editing? iOrgSoft DVD Ripper can do that job. Not only rip DVD to Windows Movie Maker acceptable videos including AVI, WMV, MPEG-1, MPEG-2, ASF, but also convert DVD to MPEG-4, MOV, AVC (H.264), MOV, 3GP, FLV, SWF.
Tutorial: How to Rip DVD to Windows Movie Maker, import DVD to Windows Movie Maker?
Step1: Locate your favorite DVD to the program-DVD to Windows Movie Maker.
Step 2: Specify output video format compatible for Windows Movie Maker, like AVI.
Step 3: Click “start” button to start the process of ripping DVD movies to .AVI video.
[img]http://www.mp4kits.com/Guides/WMM/dvd-to-windows-movie-maker/importdvdtowmm/convertdvdtoavi.jpg[/img]
12/11/2015 11:14:08 AM • Lite On... • Answered on Dec 11, 2015
2answers
Where i can buy lvw5005
You may have better luck buying one online. Maybe Ebay, the LVW 5005 is discontinued so you will probably not find it in any store
12/4/2015 12:05:59 PM • Lite On... • Answered on Dec 04, 2015
Lite On LITEON 16X DVD BLACK OEM (Come With Software) (D11663VM) DVD Drive Logo
10 questions posted
Top Lite On Computers & Internet Experts
Marvin
Marvin
Steve
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Computers & Internet
Most Popular Question
dvd rom recognize dvd movies
  • Computers & Internet
