Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
A
Anonymous Posted on Feb 23, 2014
Dashboard error has occurred
When trying to launch the shortcut from the desktop I get an error message - Dashboard error has occurred.
GETTING NERO CLASSIC TO OPEN WHEN I CLICK ON DESK TOP ICON IT DOES NOT OPEN
If you are not able to launch the Nero Classic program from the shortcut icon that appears on desktop, then the shortcut icon may be corrupted. Now to help you further, please follow the steps given below,
- Click on 'Windows Start' button and then click on 'All Programs'.
- Now search for the program 'Nero Classic' in the list and right click on it and select the option 'Send to Desktop (create shortcut)'.
- Now try to launch the program from the new desktop shortcut.
- Also you need to delete the previous corrupted shortcut icon.
GuruAid.com
tip
Recreate the Show Desktop icon on the Quick Launch toolbar
To re-create the Show Desktop icon on the Quick Launch
toolbar, follow these steps....
1. Use any text editor (such as Notepad) to create a
file with the following lines:
[Shell]
Command=2
IconFile=explorer.exe,3
[Taskbar]
Command=ToggleDesktop
2. Save the new file as a file named Show Desktop.scf
in the WindowsSystem or WinntSystem32 folder. Note
that Notepad may automatically append a .txt extension
to the file name. Remove this extension if Notepad
adds it. These steps do not work if the file is named
Show Desktop.scf.txt.
3. Quit Notepad.
4. Using Windows Explorer or My Computer, right-click
the Show Desktop .scf file, and then click Create
Shortcut.
5. Copy the new shortcut to the appropriate folder. In
Microsoft Windows 95 or Windows 98, copy the shortcut
to this folder: WindowsApplication DataMicrosoftInternet
ExplorerQuick Launch
In Microsoft Windows NT or Microsoft Windows 2000,
copy the shortcut to this folder: WinNTSystem32
In Microsoft Windows XP, copy the shortcut to the
following folder: WINDOWSSystem32ConfigSystemprofileApplication
DataMicrosoftInternet ExplorerQuick Launch
6. Rename the shortcut to Desktop.
The Show Desktop icon automatically appears on the
Quick Launch toolbar.
Reference:
http://support.microsoft.com/kb/190355/EN-US/
Why i keep getting th error oxc0000005 when i try to on chrome google
Try below steps to fix error code 0xc0000005:
1. Locate Google Chrome shortcut on the desktop or in the start menu.
2. Right Click on the shortcut and open Properties.
3. Now go to the Shortcut tab and you'll see a field named Target.
4. Add the following attribute at the end of the Target Field after giving a space: -no-sandbox
5. You are done. Now restart Chrome and you won't see that error message again.
GuruAid.com
I wish to get Facebook ICON on my desktop
Facebook allows users to keep in touch with friends and family from an easy-to-use online dashboard. You can create a desktop shortcut to the Facebook site to eliminate the steps of having to launch a Web browser and manually type in the URL of the site every time you wish to log in.
Open any Web browser and navigate to facebook.com. Click the "F" Facebook icon located on the left side of the address bar next to the URL. Hold down the mouse while you drag the icon to the desktop.
I get the error message system cannot find specified registry key or value
Try a system restore and bring computer back in time before the error occured.
I cannot get my document printed. when i try to print I get the message printer is busy then , another message that states a printing error occurred appears
Open Notepad and type the following lines:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Save it in your root directory as: C:\DeletePrintJobs.cmd
Create a shortcut for it and move it to your Desktop
Now everytime you have print job(s) that got stuck in the print queue
go to your desktop and Double Click on the DeletePrintJobs.cmd
It will clear all pending print jobs in the print queue and allow you to
print new jobs again.
Error code 13 and 16 on my xbox 1, cannot launch the dashboard and error files.... cannot find a hdd recovery disk at the net help me find one plz...
Hello Sir
13 - kernel - Dashboard launch fail (due to missing/bad key, or anything else that would prevent it from running) and the dashboard didn't specify why it failed.
16 - dashboard - Other files to do with dashboard / dashboard settings (specific dashboard error)
4helpful
2answers
I get the message "Bad check sum (CMOS)" Model toshiba tecra 730XCDT
hi friend,
Probably a dead Motherboard battery. Need to enter the BIOS screens and reset values. Especially the time and date. Maybe the boot order and if using USB KBoard enable legusy USB devices. This will occur each time your friend shuts down and reboots until the battery is changed.
Issue
When you turn your Toshiba computer on, you see an error message like: **** Bad RTC battery ****
**** Bad Checksum (CMOS) ****
Check system, then press [F1] key The Real Time Clock (RTC) battery provides power for the internal clock/calendar and for maintaining system configuration settings.
This error can occur when a machine has been left turned-off for an extended period of time (around a month), and is the result of a depleted RTC battery. Other symptoms include not being able to execute Windows Update properly, errors/problems executing application software (like Norton Antivirus), and the appearance of the Windows XP "Desktop Clean Wizard".
Resolution This condition is easy to fix in 3 basic steps: Reset the BIOS defaults
Set the correct date and time in Windows.
Charge the RTC battery Please follow the detailed instructions in the next section.
Procedure Set BIOS defaults Press the [F1] key as instructed in the error message:
Check system, then press [F1] key In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system. Set the correct date and time in Windows As Windows starts-up, you may see an error message about an "Invalid System Time". Go ahead and click "OK" to clear the error dialog. Open the Windows Control Panel and open the "Date and Time" control by double-clicking its icon. Set the correct date and time, then click OK to save. Charge the Real Time Clock (RTC) battery To charge the RTC battery, connect the AC adapter and turn the computer on (both the DC IN and Power LEDs must be green). Leave the machine on for approximately 24 hours to ensure a full charge in the RTC battery. Please note that the RTC battery does not charge while the PC is turned off, regardless of whether the AC adapter is connected or not. Other Information: If, on subsequent reboots, the "Bad RTC Battery" error persists, it's quite likely that you actually do have a bad RTC battery. If that's the case, you should contact a Toshiba Authorized Service Provider to have the system serviced. Windows XP Desktop Cleanup Wizard The first time you reboot Windows XP after resetting the system clock, Windows XP may try to run the "Desktop Cleanup Wizard". Simply Cancel the "Desktop Cleanup Wizard" at the first dialog. If you do manage to clean your shortcuts from the desktop and want to recover them, you will find them in a folder called "Unused Desktop Shortcuts". You can recover them as follows: Double-click to open the "Unused Desktop Shortcuts" folder
Drag the selected items back to your desktop
Close the "Unused Desktop Shortcuts" folder. You can delete this folder if it is empty.
thank u for using fixya
regards,
sivaranjini
2helpful
Can't get a Shortcut or Quick Launch for IE6
Hi. Try this:
Click Start>All Programs>Accessories>Windows Explorer.
In the left pane click the + next to your Local Disk C:
Click on the Windows folder name.
Still in the left pane, click on the ie6 folder name.
Now in the right pane, scroll down to the iexplore (Application) file.
Right click on the file name and go down to Send To>. Then select Desktop (create shortcut).
That should put a shortcut icon on the desktop. Then drag and drop it to the Quick Launch.
Any problems, just Comment back.
Thanks fro using Fixya.
My yahoo messager will not load when u click on it from the starst menu. i uninstalled the messager and downloaded the latest version and installed it. now when i click on the start menu for messager or...
Try this:
Using explorer go to the c:\Program Files\Yahoo Messenger (or whatever you named it) directory + right click on the program icon (EXE file) + send to + Desktop.
Than delete the old icon as it doesn't work anymore.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
