This machine is going to be used by a child. is it possible to purchase some type of attachment to guard against her fingers getting under the needle?
SOURCE: Thread getting caught
make checks on the bobbin case that holds the bobbin beneath the machine it could be broken or too tight then you need to slacken it a bit so that thread can flow easy there after oil your oil the machine if the bobbin case lever is broken or bent replace it.also adjust tension disc.good luck.
