20 Most Recent Janome 8080 Computerized Sewing Machine Questions & Answers
2answers
Memory craft 8000 how do you take it apart to
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.Janome no longer stock this item direct, but there is an affordable replacement available.Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.Check this LinkAlso includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
8/22/2019 12:47:09 AM • Janome 8080... • Answered on Aug 22, 2019
3answers
My Memory Craft 8000 visual screen is blank i
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light.https://sew-bright.com/products/janome-memory-craft-8000-lcd-backlight-replacement-kit
8/22/2019 12:32:08 AM • Janome 8080... • Answered on Aug 22, 2019
Hi, I purchased a janome 'My
YES BECUASE IS DEFECTED BRING THE PAPPER WORK MAKE SURE IS PACK'D JUST THE WAY YOU GOT IT.AND DO YOUR SELF A FAVOR DON'T BUY ANYTHING MADE OUT OF PLASTIC UNLESS IS A PLASTIC CUP. WHAT'S WRONG WITH A METAL MACHINE? IF YOU BUY A METAL MACHINE YOU CAN SET IT ON A TABLE.IF YOU WORRY ABOUT MOVING IT THAN YOU CAN BUY A SMALL TABLE WITH WHEELS.. I WILL GIVE YOU A PERFECT EXAMPLE,,,WHEN YOU DRIVE ANYWHERE AND YOU SEE A CAR ACCIDENT THE FIRST THING YOU'LL SEE IS PLASTIC ALL OVER THE STREET....OK!!
2/5/2018 6:49:30 AM • Janome 8080... • Answered on Feb 05, 2018
2answers
I have a Janame Harmony 8080 and the bobbin case
local repair guys usually have spare parts and can fix these quickly.
11/7/2017 6:33:38 PM • Janome 8080... • Answered on Nov 07, 2017
2answers
LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
11/1/2017 11:28:09 AM • Janome 8080... • Answered on Nov 01, 2017
2answers
I have a janome 8200, when sewing the top stitch is perfect but top thread bunch under neath and no bobbin thread appears to be used, I have changed threads, bobbins and needle,
Be sure to use a brand new needle. Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread the upper thread. This allows the tension disk to release so the thread will seat properly. Verify that the thread path is correct. Check that the bobbin is installed correctly (turning the proper direction in the bobbin case) and the bobbin case tension is threaded correctly. Set the upper tension to the midway point. (This is the beginning point and may need tweaking later.) Pull the bobbin thread to the top of the sewing project. How and Why to Bring up the Bobbin Thread P.S.--this works with regular sewing, not just for quilting. Lower the presser foot and test your machine. Begin sewing slowly. If there are still issues--upper thread looping, try tightening but if it doesn't improve, the tension mechanism may not be working properly. Check and remove any thread pieces or gunk stuck in the tension mechanism. If still not working, it probably needs service. If the bobbin thread is still not connecting with the upper thread, the sewing machine's timing is most likely off. (Search the internet for "sewing machine timing." There are multiple web sites and videos available that discuss this OR take it for service.) ...
10/8/2016 8:27:56 PM • Janome 8080... • Answered on Oct 08, 2016
2answers
Display screen has gone out on Janome 8000 machine.
The part is an LCD screen that needs to be rebuilt by the Janome Company. You will need to take the machine to a Janome dealer for this repair because Janome only sells to it's Dealers.. Plan on spending more than $300.
sewman7
11/7/2015 6:18:50 PM • Janome 8080... • Answered on Nov 07, 2015
2answers
Sewing leather
leather needles, they make little cuts in the leather as opposed to normal needles that try to punch wholes, which does not with such dense material as leather.
3/6/2015 7:29:45 PM • Janome 8080... • Answered on Mar 06, 2015
Which parts on my Harmony 8080 (Janome) sewing machine do I oil.
Do you have a manual? Most Janomes have a sealed oil system meaning you don't ever oil anything besides the little wick under the bobbin case, just one drop now and then.
2/2/2015 9:28:53 PM • Janome 8080... • Answered on Feb 02, 2015
How do I insert the needle
flat side goes to the back of the machine,, and the needle that has a groove in it,, has to have that groove match the notch in the needle holder..
12/22/2014 3:40:10 PM • Janome 8080... • Answered on Dec 22, 2014
Instruction manual
8/24/2014 3:59:26 AM • Janome 8080... • Answered on Aug 24, 2014
I have lost my manual for my Janome new home 636 can you help?
Janome Stockport UK phone number is 01616666011. They are always very helpful.
6/18/2014 5:44:45 PM • Janome 8080... • Answered on Jun 18, 2014
Needle thread wont pick up bobbin thread
I have found this happens when I need to replace the needle. It might be slightly bent, or the tip broken. Needles are cheap, so when in doubt replace the needle!
5/7/2014 8:49:27 PM • Janome 8080... • Answered on May 07, 2014
Left prong is broke off the machine plug.
If the power inlet on the actual machine is broken, you will need to find a local Janome dealer and see if the part is still available to order, or any sewing repair shop that deals in servicing all brands may have an old one from a deceased machine that will suit you.
I am not familiar with this model in Australia, it may have come out with a different code reference here.
Phone around locally is my suggestion, we here come from all around the world.......beyond the oceans of where any of us call home !!
5/6/2014 12:23:59 AM • Janome 8080... • Answered on May 06, 2014
0answers
0answers
2answers
My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
1/3/2014 5:33:03 AM • Janome 8080... • Answered on Jan 03, 2014
Janome 8080 Computerized Sewing Machine Logo
131 questions posted
Top Janome Sewing Machines Experts
Joseph Hoffmann
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
janome 8200 when sewing top stitch
  • Sewing Machines
