20 Most Recent Sew Smart Compact Cordless 17390B Sewing Machine Questions & Answers
Possible
you need to change the needle, if it is a little broken at the head, it's not grabbing the underthread.
goog Luck
Sew Smart... | Answered on Aug 29, 2014
You just have to look hard on the internet
there is a lot of free manuals out there
perhaps this website Can be helpful
http://homeappliance.manualsonline.com/manuals/mfg/smart_parts/100_s.html
good luck
I have sew smart MINIGUHI cordless sewing machine.Its one gear connecting top shaft is broken. Iwant to replace it. From where I can get the Part
Sew Smart... | Answered on Jul 12, 2014
There seem to be a number of folks with the same machine - same problem - stitches won't form. Unfortunately, this many of the same machine with the same problem would tell us to return it and look for a different brand/model. We can only suggest the same - but have posted the following for you all to try (posted individually for another reader earlier this morning - just discovered the multiple same issues):
A few things to try:
  1. Loosen the needle screw, make sure the needle is fully up in the needle hole and re-tighten the screw. Vibration can sometimes cause the needle to slip...and the needle not fully inserted can cause this problem.
  2. Make sure the bobbin is turning the proper direction. If your machine has a standard bobbin case that comes out of the machine, turn the case so the bobbin is facing towards you. Pull the thread tail and make sure the bobbin turns clockwise. If it's turning counter-clockwise, flip it over and try your machine again. If your machine has a drop-in bobbin, double-check your particular machine instructions to make sure it's going the right direction (clockwise or counterclockwise depending on the machine).
  3. Make sure you have tension on the upper thread. Do this by lowering the presser foot (make sure the thread tail is NOT under the foot) and give the thread a tug. You should feel tension on the thread. If not, the thread isn't fully down in the upper tension disks. You should be able to give it a further tug to pull it down into the disks. No tension on the upper thread can cause the stitches to not form.
  4. If none of the above seems to help, you'll need to get your dealer involved (provided you purchased your machine from a sewing machine dealer). They can determine if it's just something happening during threading or if the machine is out of timing. They are there to help you before AND after the sale and should be willing to take care of whatever is happening.
  5. If you did NOT purchase your machine from a dealer, and the store you purchased from does not have a sewing machine technician, we would suggest that you return/exchange it for a new machine and see if the new machine has the same problem (most department/big box stores that carry machines have a very liberal return policy since they do not have personnel dedicated to sewing machines).
  6. If the new/replacement machine has the same issue, we would suggest you return it (no sense frustrating yourself) and perhaps find a local sewing machine dealer to purchase a machine from. Authorized sewing machine dealers are geared towards providing machines and service (before and after sale) and are worth the extra $ for the peace of mind and knowledge that you'll have someone local to call on for help.
Best of luck with your machines - we hope it's something minor and you're up and sewing soon! Don't hesitate to reply to this post if we can offer further help, ideas or suggestions.
Happy sewing,
Kim & Linnette
www.sewingexpressions.com
Sew Smart... | Answered on Sep 14, 2011
Good Morning,
Best of luck with your machine - we hope it's something minor and you're up and sewing soon! Don't hesitate to reply to this post if we can offer further help, ideas or suggestions.
Happy sewing,
Kim & Linnette
Sew Smart... | Answered on Feb 26, 2009
Good morning,
Unfortunately, if the needle bar is not attached to anything, you'll need to return it to the dealer you purchased from for a repair/replacement (depending on how long you've had your machine). If the needle bar has become detached, it is not something that you can easily repair yourself (re-timing the machine may be necessary).
If you did not purchase from a machine dealer, and your machine is no longer under warranty, you'll need to check with the store you purchased from regarding their return/replacement policy. If they cannot take care of the problem, you'll need to find a local sewing machine dealer who will. Most authorized sewing machine stores have technicians who can work on just about any machine - and many do not charge for just taking a quick look to determine if it's an easy fix.
Sorry we don't have a better answer - that you can take care of yourself - but sometimes things happen that just require a professional tech to look into.
Good luck,
Kim & Linnette
Sew Smart... | Answered on Jul 23, 2008
this is some ******* ****!
Sew Smart... | Answered on Jun 26, 2008
It is tempting to say something about a haystack in reply, could you be a little more specific ?
Can you go to the place where you bought it, or call them ?
If you are in an urban community, find a sewing machine dealer and ask for a replacement to suit the machine you own........if it is less than 20 years old, it will almost certainly take a "flat back" type.
If you are in a remote community, find somewhere on the internet in your own country that will sell you some....just be sure to give details of the Make and Model
Sew Smart... | Answered on May 10, 2008
If pictures are helpful, take a look here
This is for a front loading bobbin
You have not mentioned the machine or model, so if this is not like yours, it will be a top loading or drop-in bobbin.
In either event, the idea is to pass the thread thru a small slot and thereby between a tensioning spring......your Instruction manual will have details for your model, tho' with a little thought, any manual for a similar machine (top or front loading) should give you the basic idea.
If you still have troubles, let us know the make & model.
Sew Smart... | Answered on Apr 23, 2008
there are some threading diagrams on sewusa.com
Sew Smart Sewing... | Answered on Feb 20, 2016
as per the instructions in your manual.
Sew Smart Sewing... | Answered on Jan 16, 2015
Sew Smart Compact Cordless 17390B Sewing Machine Logo
18 questions posted
Top Sew Smart Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sew Smart Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Sew Smart Sewing Machines
Most Popular Question
stitches not forming
  • Sewing Machines
