20 Most Recent Janome Sewist 625e Questions & Answers
There are differing opinions about canned air. Some technicians are totally opposed to its use as it will force lint and debris farther into the machine's cavities requiring a professional to clean them.
If you have been using your machine a lot even though it's only been a year, it may just need some TLC from your favorite sewing machine technician. Most machine vendors recommend an annual check, cleaning, and adjustment.
Using canned air to clean serger or sewing machine
Canned Air CAUTION
Dos and Don ts of Cleaning Lint from Your Sewing Machine WeAllSew BERNINA...
Janome Sewist... | Answered on Apr 02, 2017
have you applied any lubricant to the bobbin holder the one that holds the bobbin? I would suggest using your manual and lube your machine. sounds to me like your mechanism is sticking.
Janome Sewist... | Answered on Jun 08, 2015
If you're in the US, contact Singer Customer Support at 1-888-633-8635 Monday through Friday 8AM to 4PM CST.
Janome Sewist... | Answered on Dec 15, 2014
Look on machine for little red dots with a small hole nearby. Usually these are near the threading points and also on the foot near or on the metal flap. Also they may be under the flap near the bobbin. Make sure you wipe the excess oil off before using.
Janome Sewist... | Answered on Oct 16, 2014
The same as a regular needle a twin goes in the same. it has only one stem 8_29_2014_5_48_42_am.jpgnotice above the read is on stem this goes into the same area as a regular needle.
Janome Sewist... | Answered on Aug 29, 2014
try these 2 sites for a manual
sewvacdoctor.com
a1sewingmachines.com
Janome Sewist... | Answered on May 07, 2014
Are you talking about feet or bobbins? Did you buy the machine new? Do you have a manual?
In my experience of this type of machine, the bobbins were plastic
Janome Sewist... | Answered on Oct 20, 2013
You're set to zig zag, reset the knob to straight stitch
Janome Sewist... | Answered on Mar 28, 2013
try changing the needle
make sure the thread has not come off the thread take up lever
try turning the bobbin the opposite way
Janome Sewist... | Answered on Jan 11, 2013
Check that the bobbin winder on top of the machine is clicked to the left or disengaged.
Janome Sewist... | Answered on Jun 11, 2012
Hello
My first guess is the needle is in backwards; my second is that you're not hanging on to the end of the top thread as you're lowering the needle.
lift the presser foot and pull about 7" of thread through the needle.
Drop-in bobbins collect a lot of lint in the bobbin case and need frequent cleaning. The bobbin thread can sometimes pull out of the guide on the side of the bobbin case.
Last resort - the timing needs to be re-set and this means a trip to the shop.
It is very unlikely a tension problem.
Janome Sewist... | Answered on Aug 29, 2011
More than likely. You mount the walking in place of the regular foot. You just have to attach the fork over the needle clamp screw at the same time.
Janome Sewist... | Answered on Apr 28, 2011
Janome Sewist 625e Logo
32 questions posted
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
sewing manual
  • Sewing Machines
