This is our 4th season and we have gotten several different answers on when we should repalce sand and where is the best place to get it?
It really depends on your climate, pool usage, and the dirtiness of your water overall.
If you look at the substrate in your filter and it looks pretty bad replace it.
I would say if you haven't replaced it yet and, it's your 4th season, it is probably a good idea to do so. You can find the diatemous sand at Lowes, or other home improvement stores for less than at some pool supply stores. And, it is easy to replace it. So, if it helps your water stay clear and clean, and is easy and fairly inexpensive to do, then its a no brainer.
As a rule we replace ours at 3 years and it has worked for us with good luck over 10 years of pool use. If i lived in a warmer climate, say Ga or FL i'd probably bump it up to every 2 years.
