Question about Soyo DYLT032D 32 in. LCD Television
Trying to fix my tv an need to try this button that is mentioned in another post. Main?logic board where is it located on my TV?
SOURCE: My Soyo DYLT032 has power but no picture or sound
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one. Plugged it in. Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed. It is located to the right of main processor on the board. You can't really miss it.
With the TV plugged in, I pressed the suspect button. The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck. In the event you are still in need of a power supply board, email me. I have a spare now it seems. ;)
Posted on Jan 20, 2009
SOURCE: bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Posted on Feb 25, 2009
SOURCE: cannot remove the stand on the 26 inch LCD tv (soyo)
Hello you remove the last four screws on the back of the tv located down at the bottom theres two on each side the stand will slide out...
Posted on May 09, 2009
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
Posted on Jun 30, 2009
SOURCE: Our remotes suddenly stopped working.
Tries take the remotes aparts.Take some Q tips soak it with some rubbing alchahols.Clean the PCB circuits board and the rubbers films between them might help,could work after do the cleaning.Not,than sorry ur remotes CPU probally it shorted and dead.That why the remotes not functioning any more.
Posted on May 24, 2010
Jul 13, 2018 | Samsung Televison & Video
May 17, 2015 | Hitachi Televison & Video
Nov 04, 2017 | Magnavox Televison & Video
Aug 22, 2011 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Jan 30, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Dec 28, 2008 | Soyo DYLT032C 32 in. LCD Television
Dec 10, 2008 | Soyo DYLT032C 32 in. LCD Television
Dec 17, 2017 | BenQ DV2050 20 in. HD-Ready LCD Television
Jul 12, 2008 | Soyo DYLT032D 32 in. LCD Television
May 19, 2008 | Soyo DYLT032D 32 in. LCD Television
